Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: Spark Plugs
Old 05-23-07, 07:24 AM
dwn dwn is offline
Cadillac(s): Cadillac Catera
View dwn's Photo Album
Casino Cash: $270
Spark Plugs
I've got a 97 Catera and I need to change the plugs..
What is evryone using and why?
Thanks
  #2 (permalink)
Old 05-23-07, 07:27 AM
dwn dwn is offline
Casino Cash: $270
Re: Spark Plugs
Oh, I also need to know about O2 sensor is it before or after the cat..
  #3 (permalink)
Old 05-23-07, 09:35 AM
todd2fst4u's Avatar
todd2fst4u todd2fst4u is offline
Cadillac(s): 1998 Catera
View todd2fst4u's Photo Album
Casino Cash: $6159
Re: Spark Plugs
there are 4 o2 sensors total. one before and one after the cat on both the passenger and driver side
  #4 (permalink)
Old 05-23-07, 07:43 PM
dwn dwn is offline
Casino Cash: $270
Re: Spark Plugs
Thanks for the info on O2's todd
Any info on plugs?
  #5 (permalink)
Old 05-23-07, 08:07 PM
PEETYZ's Avatar
PEETYZ PEETYZ is offline
Cadillac Owners Enthusiast
View PEETYZ's Photo Album
Casino Cash: $1902
Re: Spark Plugs
Try to clean your o2 sensors with electric cleaner (autozone) or throttle body cleaner with a tooth brush. I did and the code went away showing a bad o2 sensor if you must get a o2 sensor www.summitracing has a direct fit NGK sensor for 69.99 much cheaper than anywhere else. Spark Plugs i have heard the splitfire triple platinum or E3 spark plus are good they can be found at summitracing.com too best of luck -Pete
  #6 (permalink)
Old 05-25-07, 01:16 AM
Po Pimp Po Pimp is offline
Cadillac(s): 92' Eldorado, 97 Catera
View Po Pimp's Photo Album
Casino Cash: $2197
Re: Spark Plugs
I personally would steer clear of three and four electrode tip spark plugs in these types of engines. They are high compression engines. The last thing you want in a situation like this is more surface area blocking the spark from the air that needs to be ignited. Most likely it will retard the timing in the assumption that you are running on low octane fuel. I am not knocking these types of spark plugs they do serve a purpose but not with a high compression engine in my opinion. I would say their claims would be true only with different type applications. I think you are better off with cheap plugs. Look for ones that are single electrode tips. Platinum is good, double platinum is better, and irradium is the best in terms of how long they last. These engines do have aluminum heads which can be problematic when it comes to removing plugs. If you where to go with something like irradium it might be in your best interest to break the plugs off every year or so and retorque them. A different alternative would be to buy cheaper plugs and simply do it more often. Sounds like over kill but anyone who has broken a spark plug off in a DOHC will tell you it sucks BAD.
Tags: ,
plugs, spark
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
