Originally Posted by todd2fst4u |
*BRAINSTORM*
- Look at this picture above. The intake you put on, (with the filter,) - is hanging to the left like everybodys from the other hose. I brought up the concept of a harness because in my car anyway, I don't like how the intake just slumps over with nothing to support... so looking at THIS picture above, I had a simple idea I thought I'd share.
Step 1. ZIP TIE the radiator hose next to the intake to the side of your car. The perfect spot to connect the zip tie is a small hole where the ORIGINAL FILTER BOX once mounted. It's on the wheel-well - it's where the filterbox was held in place, no screw hole - it's just a small hole that the filterbox had notches for to position it level. You'll know what I'm refering to when you look. This takes care of the hose NEXT to the intake problem...
Step 2. ZIP TIE the lower portion of the intake to the hose BEHIND the intake itself. This is hard to explain, but if you look at the picture above again - you can follow me here. DON'T ZIP TIE ANYWHERE ON THE NEW CHROME PART OF THE INTAKE - just Zip Tie lower where the black original hose is... below the bend. You'll need a long zip tie - because my idea is to rap the other end of the tie around the black hose directly behind it. You know - the 2 big hoses in the engine itself, smack dab in the middle. I don't know the name lol - but it's an idea. Any problems with it?
