| Re: 1998 Catera Problems (HELP) I had a similar problem on my '99 Cat. The symptoms sound the same. The end result was the ABS module had gone bad. If this is the case with you, stay away from the dealership. Just for the module alone, they wanted to charge me
$1,082 and some change.
I went hunting around and found a salvage yard in Seymour, CT that had Catera spare parts. End result:
ABS module -- $100.00
Shipping -- $15.00
Getting someone reasonable -- $150.00 (vs. $600.00 labor at the stealership)
Salvage ABS module installed and working properly & solving the problem............PRICELESS!!!! |
