Spark plug wire instalation
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, Spark plug wire instalation in Past Cadillac Vehicle Discussion; I am trying to repalce the #1 spark plug wire. Can anyone tell me how to complete this task. I ...
    White Catera is offline Cadillac Owners Member
    Mar 2004
    1
    ExclamationSpark plug wire instalation
    I am trying to repalce the #1 spark plug wire. Can anyone tell me how to complete this task. I can trace the wire from the front side but then it disapears behind the motor. Help my Caddy's running bad.
    Vesicant's Avatar
    Vesicant is offline Cadillac Owners Connoisseur
    Automobile(s): None :(
    Nov 2003
    Jacksonville, FL
    2,703
    PostRe: Spark plug wire instalation
    See, the Catera has a system called Coil on Plug or COP. The ignition coil is precisely on or near the sparkplug itself, this minimizes resistance and is a better design. The wire your seeing is going to a electrical output center... from there it goes directly to the coil sitting ontop of the sparkplug.
    Usually, that voltage output would be in the back center of the engine, it is on most.
    Now before you go changing wires, what exactly is the problem your having with it? If the coil goes bad itself, then you need to replace that... thats a likely problem on this system if your not getting any spark (its how and why COP was designed). The wire carrying the juice wont usually go bad. You can tell if the coil is getting voltage (which is the best place to start in this situation), this site is very good and explains everything about COP and even mentions our car too...
    http://members.aol.com/carleyware/library/copign.htm
