Daytime Running Light burned out
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, Daytime Running Light burned out in Past Cadillac Vehicle Discussion; My drivers side DRL burned out on my 2000 Catera, and I never changed one before. It looks like it ...
    2000ForrestGrnCatty's Avatar
    2000ForrestGrnCatty is offline Cadillac Owners Fanatic
    Automobile(s): 1992 STS
    Oct 2006
    Detroit Burbs
    210
    My drivers side DRL burned out on my 2000 Catera, and I never changed one before. It looks like it might be hell to get to. I had to change a regular low beam bulb about a month ago, and had to take out the battery to get to it.
    Will it be the same way with the DRL? Or can I reach it from the bottom of the car. Also, should I just change both at the same time, because one is quite a bit dimmer than the other. Thx for the help guys.
    Lawrence_C is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    70
    Re: Daytime Running Light burned out
    I thought the DRLs use the same bulbs as the low beam ones. There are separate bulbs?
    todd2fst4u's Avatar
    todd2fst4u is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Catera
    Aug 2006
    474
    drls are the same as the high beam bulbs
    i suggest removing the headlamp assembly completly. its much easier and probably faster
    Feb 2007
    70
    Hey todd, when you made the switch to HIDs, do you recommend turning the DRLs off?
    todd2fst4u's Avatar
    Aug 2006
    474
    you dont have to disable the drls. the drls are the high beam bulbs at reduceded voltage. i only have hids in my low beams. if you were going to be using hids in the high beams, yes you would want to disable the drls first.
    Oct 2006
    Detroit Burbs
    210
    Quote Originally Posted by todd2fst4u View Post
    Todd, how hard is it removing the assembly? Will I have to take out the battery to get to it? A step by step process would be greatly appreciated.
    Feb 2007
    70
    todd2fst4u's Avatar
    Aug 2006
    474
    1.remove the grill(4 screws)
    2.remove the trim piece below the headlamp(1 screw)
    3.remove grill/trim bracket(2 screws)
    4.remove the 3 screws holding in the headlamp(one below the bottom trim piece, 2 above the headlamp)
    headlamp should then slideout.
  11. Remove Advertisements
