Flashing CEL and rough idle for appx 20 seconds - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Cadillac Catera and Cimarron Forum Discussion, Flashing CEL and rough idle for appx 20 seconds in Past Cadillac Vehicle Discussion; Well 3 days later and a call to a Cadillac specialist and they determined the problem to be a bad ...
  1. #16
    catera00's Avatar
    catera00 is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Feb 2007
    Tucson, Az
    40
    390
    Re: Flashing CEL and rough idle for appx 20 seconds
    Well 3 days later and a call to a Cadillac specialist and they determined the problem to be a bad MAF. They also replaced the #4 and 6 spak plugs I have driven it twice and so far so good. We'll see. I am optomistic this time though.
  2. #17
    catera00's Avatar
    Feb 2007
    Tucson, Az
    40
    390
    Ahh the difference a half a day makes. Same peoblem. Rough start, check engine.
    The cars goin back. Given them one last chance then the car is staying there and I'm getting something else.
    Havent even made a payment yet!
  3. #18
    txcaddycat is offline Cadillac Owners Member
    Jul 2006
    39
    That is a crazy story, and it sucks you have to go through all the trouble. At least the car's under warranty.
  5. #19
    catera00's Avatar
    Feb 2007
    Tucson, Az
    40
    390
    Well, got off the phone with the dealer. The head gasket is leaking. Not sure if I mentioned this but the coolant was being consumed but not leaking externally. I had them do a compression and leak down test and they said they didn’t find any problem. 190 across all cylinders is what the mechanic said he got. But somehow they found a leak this time. Which means they probably didnt do the leak down test last time and did it this time for real. I told the guy he needed to find out where my coolant was going. Must have put 2 and 2 together
    They are replacing the gasket and sending the head to be inspected for cracks. Finally an answer!
    Should have it by the end of the week. This time I asked for a loaner car so they can take all the time they need.
    Although a 2006 Sebring is no comparison for the Catera. Gutless.
  6. #20
    HoffmansCaddi is offline Cadillac Owners Member
    Automobile(s): Catera
    Apr 2010
    42
    9
    I know this thread is old but what happened?
  7. #21
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    Hey man, I am so glad I bumped into this post, I am having almost the exact same problem with my 2000 catera sport!!!!
    It started about a week or so ago.. I have a post on here.. rough idol that I outline the issue.
    I took it in and he said misfire in 4 and 6 also!!! relapced coilpack and all plugs,, seemed to be ok for him, I drove 15 miles, then problem again.. it stals when I turn sometimes, or at stop light.
    Ill go start it and idol is rough like it dont want to run. after a few minutes it sometimes gets better sometimes not.
    I wont even drive it right now. I am not getting a check engine light thou.. it did come on when it forst happened last week, but was on for a minute then turned off... I do know that one of the o2 sensors has a wrong reading, but its not bad enough to set the CEL so I dont forse that being the issue.. I have a warranty also.. thanks god, but it dose not cover b2b like yours. they will cover the coil, o2 sensor. My water pump is leaking slightly, and they will cover it, but I dont see why that would cause the probem.
    the car leakes no oil, there was some white build up in the oil fill spout, but I was told it was normal. even with the coolant leak, it only loses like 1qt in 7 months.. thats not much at all.. so I am all ears about possible solutions!!!
  8. #22
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Quote Originally Posted by hgqguy View Post
    I don't know if you have looked through the information in the below URL as Chapter 2 Section C covers lot of our engine items,
    http://forum.omegaforever.info/docu/..._%28eng%29.pdf
    Good luck.
  9. Remove Advertisements
