Cadillac Key Fob Failure - Suggestions request
Results 1 to 4 of 4
Cadillac BLS Forum (Europe / South Africa) Discussion, Cadillac Key Fob Failure - Suggestions request in Past Cadillac Vehicle Discussion; Hi all , I own a 1.9tdi bls(2006), my key fob has stopped responding and I think I am in ...
    pyk_30 is offline Cadillac Owners Member
    Automobile(s): None
    Apr 2014
    None
    1
    QuestionCadillac Key Fob Failure - Suggestions request
    Hi all ,
    I own a 1.9tdi bls(2006), my key fob has stopped responding and I think I am in a bit
    of a mess because of it, I am afraid if I use the key blade to enter the car from passenger side,
    then if the alarm goes off , I am unsure if it would stop , if any of you has any similar experience or idea,
    can you please suggest me something?
    Also as my keyfob is unresponsive , I was wondering if I opened the car using blade and used the fob in ignition
    would I still be able to operate it?
    Pardon my stupidity , but any advice/suggestion would help a lot ..
    Thanks,
    PK
    t4evs is offline Cadillac Owners Member
    Automobile(s): BLS 1.9TiD
    Jul 2009
    34
    Re: Cadillac Key Fob Failure - Suggestions request
    Bad luck. Could it be the battery?
    If the alarm goes off it does reset itself so don't worry about that and it is certainly worth seeing if the ignition works.
    Replacing the battery is easy and I picked up a replacement at the local diy shop. You will also need to reprogram the key puting it in the ignition after replacing the battery.
    If your key housing is broken you can buy a similar seond hand key for a saab or cadillac off ebay and swtch the circuit board and door key. I had to do that and it worked fine.
    Good luck.
    ExRPO1 is offline Cadillac Owners Fanatic
    Automobile(s): BLSd 150hp 2009
    Mar 2010
    Nottinghamshire UK
    49
    245
    I take it from reading the OP, that he only has one key fob? When I bought my car, it came with two fully working fobs, indeed, they both still work.
    Worse case scenario here is if a new key fob has to be purchased, it will need reprogramming with Tech 2 at a Cadillac dealer/authorised service centre and that won't be cheap.
    Hopefully it will be just the battery. Batteries should be replaced at least every four years anyway, as is stated in the owners handbook.
    Mazuk is offline Cadillac Owners Fanatic
    Automobile(s): BLS 180 Auto estate
    Feb 2010
    165
    Extract from manual Battery is CR2032
  7. Remove Advertisements
