1. Where is the engine number(where is it stamped)?
2.My log book states -engine number not known.Is this normal.I remember the good old days when a matching chassis/ engine number added value to a secondhand American(maybe Swedish) vehicle.
3. I have seen a reference to Z19DT & Z19DTH engines.Are these the current 150 & 180 diesels?
@mazuk,
Just checked my reg doc. I have an engine number on mine.
Mine begins with Z19DTH, followed by eight numbers. Those numbers are also the last eight numbers of my VIN.
@caddykev,I guess yours is a diesel 180.If this is correct my 180 will have the reference Z19DTH.I have seen an oil or air filter quoting this reference on ebay.Thanks for info.I will double check to find the engine number tomorrow.Two weeks and not opened the "hood" yet!!!Nice to confirm you have matching numbers
@mazuk,
Tried to upload a scan of my handbook with the location of it.
Don't seem to be having alot of luck tho!
It appears to be located on the engine at the front as you look at it from the rad grille. Slightly off centre to the right. According to my manual it is on a cylinder shaped mount of some sort. Bit like a brake or clutch master cylinder shaped thingy?!? Sorry to be vague. Probably midway down.Happy hunting Buddy!
The above is a bit difficult to follow but appears to confirm the diesel 180(177h.p.) as a Z19DTR.
Must look under bonnett for confirmation & twin turbo.
Is yours a 150 caddykev?.Your engine number suggests that it is.
Mazuk,
Yep, mine's a 150 saloon.
You found that engine number yet?
I just read back my instructions to you on how to find the engine number. I pretended to be you. You've got no chance!!!!! Lol.
Your right,I read your insructions and the manual.Looks easy to find but I never found it(or the thingy).Not an issue as I now know the 180 engine identifier.Really clean and shiny under the hood and I did not want to disturb any connections.
jerry, I will hazard a guess that the engine mount might be the same as for a Saab 9-3 (what engine have you got in your BLS?)
Anyway, best I can help you with here is the telephone number for Bauer-Millett parts department here in the UK +44 (0)161 8727744, email: parts@bauer-millett.com
I'm sure they will do their very best to help you. Usually very good to me whenever I phone them. The least they might do is give you the part number and you may well then at least be able to source the mount in SA. If the mount isn't available in SA, you might have no choice but to buy from the UK.
Alternatively, if once you have obtained the correct part number, contact: http://www.reeds.co.za/ and they might be able to get the part for you.
Hi
It is a BLS 2.0T. I am beginning to have a lot of problems with the car. The parts are not always available here in South Africa's GM. If available they are very expensive. For instance, the front wheel-bearings cost R6250, in the region of 600 pounds for one. The engine mounts are R4900 for two, around 490 pounds. Hence I am looking elsewhere for parts alternatives. I love the car, but am getting scared by the negative reports I see on the BLS models. Are we not getting into a stituation where parts may not be available anymore as SAAB, you know the story....
Where there's a will there's a way! I absolutely know more than anyone just how difficult it is to get parts for our cars in SA.
To give you an idea of what you should be paying and don't forget, even with tracked postage via a reputable courier service, they should still cost you a lot less than sourcing from SA:
You can see therefore, that you shouldn't be paying anymore than a couple of thousand Rand per pair of bearings minus postage.
If you look carefully at all of the X reference numbers between the Cadillac, Saab and Vauxhall (Opel), you will see that they all share the same part number.
Obviously, you would have to check the part numbers against anything you bought, can't highlight that enough.
If you scan the UK site of ebay, you'll find engine mounts listed for the Saab 9-3 which will could well do the trick, but again, you would have to check absolutely thoroughly yourself.
Good luck mate!
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
