4 ohm speaker
Results 1 to 4 of 4
Cadillac Audio, Video and Security Systems Discussion, 4 ohm speaker in Item Specific Cadillac Discussion; just bought 4 ohm infinity speakers for a 1992 delco deville radio/ cass, quick question what will happen if i ...
    jetengine is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2007
    82
    4 ohm speaker
    just bought 4 ohm infinity speakers for a 1992 delco deville radio/ cass, quick question what will happen if i do hook this up, and what is the ohms for this radio, would like to keep everything stock, thanks
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: 4 ohm speaker
    i think those factory were either 10 or 8 ohm
    it shouldnt hurt anything
    but they will prob sound louder than your rear speaks so you may wanna fade it
    EldoRedo's Avatar
    EldoRedo is offline Cadillac Owners Fanatic
    Automobile(s): 1991 ETC (Crimson)
    Jul 2006
    Bethesda, Md.
    232
    Re: 4 ohm speaker
    I also just bought 4 ohm Infinity speakers for a 1991 Delco ETR am/fm/cass/eq. Yes, the factory speakers were 10 ohm. I have been reading very conflicting accounts. Some say, it's fine. Others say, you'll burn out your radio.
    PineyJustice is offline Cadillac Owners Fanatic
    Automobile(s): 2001 deville base, 2008 dts
    Apr 2012
    Michigan
    27
    310
    Re: 4 ohm speaker
    The new speakers are lower impedance, this means you will definitely do some damage if you crank the volume up. If you put 4 ohm speakers in, you are cutting the resistance of the speakers in about HALF, which means as a rough estimate the head unit will try to drive between half again and double the power to those. The radio and amp will operate fine at lower volumes, but if you accidentally crank it up past the point where it is driving the stock ones the 20 year old amp/radio handling being driven that far out of spec is anyone's guess.
  7. Remove Advertisements
