Go Back   Cadillac Owners Group > General Discussion > General Cadillac Discussion > Cadillac Audio, Video and Security Systems
Cadillac Audio, Video and Security Systems Section for discussions in relation to stereo, navigation, DVDs, alarms, etcetera.
Cadillac Forums: My 2002 Seville XM Direct Wiring Guide
  #16 (permalink)
Old 07-15-07, 12:36 AM
Cadillac(s): 2001 Seville STS
View eclipse5302's Photo Album
Casino Cash: $250
Re: My 2002 Seville XM Direct Wiring Guide
From what I could tell, the SIR-GM1 has a data pin in, and a data pin out. If you can control the SIR-GM1 from your radio, you've got the data pin(s) right. All that unit needs is 12V, GND, DATA, AUDIO LEFT, AUDIO RIGHT, and AUDIO GND.
Besides, it's not like you are missing much. The SEL button only scrolls through the presets on my car...just like it does with the AM and FM bands. All I really lost was the up/down method of going through presets (I can only go up through the presets now).
Does it function differently on other cars?
  #17 (permalink)
Old 07-15-07, 02:14 PM
Cadillac Owners Enthusiast
Cadillac(s): 02 Seville, 04 SRX
View Yaemish's Photo Album
Casino Cash: $2425
Do you have the data in and the data out both connected? I only have one data pin connected, the other didn't do anything. Maybe the other did something but I just need to change where they are going.
  #18 (permalink)
Old 07-15-07, 02:30 PM
Casino Cash: $250
No, I am only using one. They are both connected internally, so there is no need to connect both of them. I figure that their intended use is for when you are using the pass-through cable (that little 12-pin Y-harness). That way, they don't have to splice two wires together.
  #19 (permalink)
Old 07-16-07, 08:46 AM
Cadillac(s): 2002 Seville STS
View aplusdj1's Photo Album
Casino Cash: $250
Per the Specs of the SIR-GM1 it only supports the Up function on the steering whhel.
Also I had the TERK XM Direct unit and switched it out to the SIR GM1. Funny thing is both boxes are made from a different manufactor but the wiring and plug are the same.
Just as an FYI the SIR-GM1 functions and sounds better than the Terk XM unit.
  #20 (permalink)
Old 07-16-07, 12:14 PM
Cadillac(s): Cadillac 2002 Seville STS
View drfong's Photo Album
Casino Cash: $905
eclipse, thanks to going to all that trouble, but it sure is nice to know. I'm bidding on a sirus gm-1 unit on ebay. If I get out bid, I'll just bid on the next one. Eventually I'll get one for what I want to pay. Sounds like the sirus is prefered by most people for programing also.
  #21 (permalink)
Old 07-16-07, 10:03 PM
Casino Cash: $905
Just won the sirus unit on ebay and should have in a few days. I gues I'm a little confused because I have been reading so many different ideas about this. Just to confirm before I get into the install, the unit plugs in where the CD changer plugs in. I am assuming there are enough empty pin locations in the connector to have the sirus and the changer both pluged in. That's where all the directions have me confused. Does anyone have a diagram or directions for where all the wires go from both the sirus and the cd changer.
  #22 (permalink)
Old 07-16-07, 10:07 PM
Casino Cash: $250
Actually, you will be "tapping into" the wiring that goes to the changer. I suggest solidering and taping the connections. What year and model car Seville do you have? If it's 2002 and up all of the wires you need are in that harness.
  #23 (permalink)
Old 07-16-07, 11:06 PM
Casino Cash: $905
its a 2002 sts. I guess that is where I'm confused. The cd player and the siruse unit conect to the same wires in the car harness and it still recognises which one you want to play?
  #24 (permalink)
Old 07-17-07, 09:34 AM
Casino Cash: $250
Both units tie in on the same wires. The sound is controlled through the source selector.
  #25 (permalink)
Old 07-17-07, 12:39 PM
Casino Cash: $905
so just leave the changer as is and attach the sirus to the apprpriate wires as described in the original post, wireing diagram.
  #26 (permalink)
Old 07-17-07, 09:52 PM
Casino Cash: $2425
If you look in the Video and Security section of this site, I did a post on how to install it.
  #27 (permalink)
Old 07-17-07, 11:39 PM
Casino Cash: $905
Thanks, i've seen your install. I'm just not sure because your install does not include the changer. I have one in my car.
  #28 (permalink)
Old 02-08-08, 04:37 AM
Cadillac(s): 2000 Seville SLS
View dirtyguido's Photo Album
Casino Cash: $1120
Did you ever solve the switched power issue you were having?? I read you asking about it in your PDF file.
If not, here's the answer: Fuse #2 in the Underhood fusebox, is marked Accessory.(at least on my 2000 SLS) your mileage may vary, but there should be one there.. It behaves the exact way the radio does. I.e. turns on off with the key etc, plus stays on until you open a door to exit etc.
If you use a fuse tap, and run a wire into the car, you now have a source for accessory switched power, so whenever the radio is on, your xm will be on as well.
Take care,
George
  #29 (permalink)
Old 04-16-08, 11:49 PM
cadmanchris's Avatar
Cadillac(s): 2001 Cadillac DTS, 2006 Cadillac SRX
View cadmanchris's Photo Album
Casino Cash: $580
FYI, I bought a T harness from Radiosandmore.com that plugs right in to the changer harness and has the SIR-GM1 plug on it. It should work with or without a changer.
  #30 (permalink)
Old 04-17-08, 02:25 PM
Casino Cash: $2425
I tried it without the changer and it doesn't work.
Tags: , , , ,
2002, direct, guide, seville, wiring
