Go Back   Cadillac Owners Group > Cadillac Technical Discussion > Cadillac Audio, Video and Security Systems
Cadillac Audio, Video and Security Systems Section for discussions in relation to stereo, navigation, DVDs, alarms, etcetera.
Cadillac Forums: attaching a sub-woofer
Old 01-12-03, 06:13 PM
Mr Seville Mr Seville is offline
View Mr Seville's Photo Album
Casino Cash: $250
mmk heres the deal i have the bose-gold system in my 92 sts and i want to attach a sub to it. how should i go about doing this? should i attach a new amp or attach it to an existing one??? so confused to many wires
  #2 (permalink)
Old 01-12-03, 06:20 PM
Casino Cash: $250
and how would i run it to the trunk???
  #3 (permalink)
Old 01-13-03, 08:54 AM
BeelzeBob's Avatar
BeelzeBob BeelzeBob is offline
I'm a Cadillac Fanatic!
View BeelzeBob's Photo Album
Casino Cash: $250
Hmm. There's an existing amp? Where is it? Is it attached directly to speakers? I think you should run another amp and attach the new speaker to it.. This way you don't disturb what's already connected. If you did, all your other speakers would lose power while the amp you already have - which was probably designed perfectly to power your current speakers - will use power to run the new speaker...
Did that make any sense?
  #4 (permalink)
Old 01-13-03, 11:13 AM
jeff___H's Avatar
jeff___H jeff___H is offline
View jeff___H's Photo Album
Casino Cash: $250
www.crutchfield.com 1-888-955-6000. They should be able to give you an answer. Their customer information line is VERY good.
  #5 (permalink)
Old 01-13-03, 04:20 PM
Casino Cash: $250
thanks for the imput guys
  #6 (permalink)
Old 02-03-03, 08:01 PM
seduxion seduxion is offline
View seduxion's Photo Album
Casino Cash: $250
I personally haven't ripped my dash apart yet... However if for some reason they had the foresight to install rca jack/pre outs in the back of the factory deck then you are set. If not then you need a line level converter and a wire harness for the system. Unless you feel like splicing into the factory wiring which I highly discourage. It's like painting the car with house paint. Anyways get a pair of RCA's to the trunk and mount a decent amp back there and run them subs.
I have 4 12" JL Audio's to install. I need to make a new box because the trunk is 2" narrower than my contour was.
- Scott Weston -
97 STS
  #7 (permalink)
Old 02-04-03, 08:49 AM
Katshot's Avatar
Katshot Katshot is offline
Cadillac Owners Master
View Katshot's Photo Album
Casino Cash: $1455
It's a simple task to tap into the line-level wires to either rear speaker and then either use line-level inputs, or a converter to RCA's. That's you input. All you need then is an amp and sub, or a powered sub, and some power and ground. Don't forget to run the turn-on signal wire too which can easily be tapped into the OEM antenna relay. I would also recommend a cross-over filter for the unit. I did it on mine and it sounds great.
  #8 (permalink)
Old 02-13-03, 03:06 AM
eldawg4100 eldawg4100 is offline
View eldawg4100's Photo Album
Casino Cash: $250
hmmm i would go with the hi-lo convertor...
also...using antenna as a turn on? As a car audio installer, i know that doesnt have good results most of the time... sometimes, it just doesnt work on certain cars. i would find the turn on wire ON the bose amp with a test light.
  #9 (permalink)
Old 03-06-03, 03:44 PM
jerseyMan's Avatar
jerseyMan jerseyMan is offline
View jerseyMan's Photo Album
Casino Cash: $250
I recently had a 10" subwoofer (JL 10IB4) installed in the existing hole on the rear seat panel. Also installed a JL 250/1 amp (attached to rear seat in the trunk). Had a bass control installed below and to the right of the steering column. It made the Bose CD system sound much better - fuller sound all around & improved the kick in the bass response for the low end sound that was lacking.
Did this on a 2000 STS for a total price of $600 (included components, install, tax)...not a bad deal if you're not willing to tackle it yourself.
  #10 (permalink)
Old 03-06-03, 03:45 PM
jerseyMan's Avatar
Casino Cash: $250
If it would help, I can provide pics although it is pretty straigtforward.
Tags: ,
attaching, subwoofer
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
earn
vacation travel
golf store
silver, gold, diamonds
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
