'97 seville door panels...HOW do you remove them?
Results 1 to 5 of 5
Cadillac Audio, Video and Security Systems Discussion, '97 seville door panels...HOW do you remove them? in Item Specific Cadillac Discussion; I did a search in this forum w/ only '97 and older devilles coming up can someone tell me how ...
    1997 Cadillac SLS's Avatar
    1997 Cadillac SLS is offline Cadillac Owners Member
    May 2006
    Virginia
    23
    Post'97 seville door panels...HOW do you remove them?
    can someone tell me how to remove the front & rear door panels in a '97 seville SLS
    thanks for any help
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: '97 seville door panels...HOW do you remove them?
    easy man it should be the same for my eldo
    1. gently pull off the door handel and lock bezel and disconnect the plug for the power locks.
    2. use a flat head screwdriver to pry up the power window bezel behind there should be a screw remove it as well.
    3. at the end of the door panel in the upper coner of the pocket pull it away there should be a phillips screw behind there remove it too.
    4. lift up on the door panel it should come up and out.
    there you have it man good luck
    this should work for both front door panels im not sure about the rear but there are no speakers in the rear doors so you shouldnt need to remove them.
    May 2006
    Virginia
    23
    cool...thanks bro!~
    Maxfli's Avatar
    Maxfli is offline Cadillac Owners Member
    Automobile(s): STS'97
    Jul 2005
    West Palm Beach
    58
    49
    Quote Originally Posted by CadillacSTS42005 View Post
    anyone have pictures? I removed the window bezel but saw NO screws. I also went all over the door pocket and again there were NO screws. There was a screw when I removed the door handle bezel. Any ideas? 1997 Seville STS.
    Le129183 is offline Cadillac Owners Member
    Automobile(s): '99 Seville STS 125k Miles
    Jan 2012
    Arlington, TX
    23
    14
    On my '99 right where the door handle. There is a sort of flap of leather (post piks tomorrow) lift it and there are 2 screws and that is all that holds in place . Afterwards there is a black brittle plastic cover that is easy to break if your not careful
  8. Remove Advertisements
