alarm problems
Results 1 to 2 of 2
Cadillac Audio, Video and Security Systems Discussion, alarm problems in Item Specific Cadillac Discussion; Over the last few days i have had a problem with my key fob. Some times it works and sometimes ...
    jdeville99 is offline Cadillac Owners Member
    Mar 2006
    36
    24
    alarm problems
    Over the last few days i have had a problem with my key fob. Some times it works and sometimes it doesn't. If it doesn't then when i use the key to open the door i have no power in the car until i start it and then the alarm goes off. The car will run just fine and everything but the horn honks and the lights blink and so on. It will do this for about the first 3 or 4 times i start it and then i can hit the unlock button on the key fob and it will stop and run just fine for a few days again. This same thing happened when i had my aftermarket stereo installed 3 years ago. The installer corrected his mistake then. This is a 99 Deville. PLease help me figure out why its doing this. thank you.
    thebigerrn is offline Cadillac Owners Member
    Automobile(s): 1999 Deville 50th Anniversary Edition
    Oct 2011
    Re: alarm problems
    did you find the problem? I have the same issue with my 99 Deville.
