aftermarket radio and speaker fitment for a 95 deville - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Cadillac Audio, Video and Security Systems Discussion, aftermarket radio and speaker fitment for a 95 deville in Item Specific Cadillac Discussion; Sounds pretty good to me. What he is saying is to run 4 of the speakers off from the head ...
  1. #16
    JC316 is offline Cadillac Owners Connoisseur
    Mar 2005
    DFW Texas
    30
    1,406
    Re: aftermarket radio and speaker fitment for a 95 deville
    Sounds pretty good to me. What he is saying is to run 4 of the speakers off from the head unit and three off from the 4 channel amp. For example.
    Run the door speakers and 2 dash speakers off from the head unit. Then run the 2 deck speakers and the center channel off from the amp. I had a similar system in my Mark VIII, only I had 8 speakers running.
  2. #17
    yafuturehubbie is offline Cadillac Owners Member
    Nov 2005
    queenz NY
    35
    ok sounds like a good idea but now i have a nother problem , the guy at best buy was right i actually have to run all the wiring to the front in order to install the indash monitor, any suggestions on thw wiring from the trunk to the dash ? or if there is a kit that is available?
  3. #18
    Mar 2005
    DFW Texas
    30
    1,406
    Why would you need to go from the trunk to the dash? If you are replacing everything, just run new wires.
  4. #19
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    second that run your own wires you dont know how your stock ones are run and for what so rather than risk it just ditch them
  5. #20
    clarkm2005 is offline Cadillac Owners Member
    Dec 2005
    Just a note - You can tell if you have an active audio system if the rear doors have small speaker grils in the arm rests. If they don't - you probably dont have an amp - the origional factory active audio is 11 speakers - two in each door - one in the armrest, and one in the lower door - the dash has one in the center, and two in the rear shelf. The Amp is located in the trunk - remove the panel covering the back seat, and you will find it, along with the ride conputer - security system, keyless entry, etc.
    If it has a 5 band Equalizer, and no speakers in the rear doors, then it is a seven speaker system, on four ouputs - two in each front door, two on the rear shelf, and one in the dash. I don't think that type of system has an amp. It sounds like you have the higher-end system. I replaced the 7 speaker system in my 95 deville with a Pioneer DVD/GPS Touchscreen, and used the factory speakers with no problems. While in my Seville (a 94) I had to do the whole system, as it had a built in amp. In the end - I reused some of the existing wiring in the Seville, and re-ended with new conectors. I did however inistall a new aftermarket amp in the trunk in pleace of the old one. This made use of the existing factory wiring easier.
    Hope that helps a little.
  6. #21
    Nov 2005
    queenz NY
    35
    yeap i have the active audio system , its such a PAIN in my $%^#$% ASS grrrrr my friend has the same exact car but has the 5 band eq and his wire harness attaches in the front with no problem mind u mine is all the way in the trunk although he doesnt have his speaker on the dash and doesnt have the speakers in the door as uppose to mine where i have them , but anyways what i am going to do is use the existing wires because im not trying to spend an arm and a leg on wires and then the hassle to re-wire pretty much the entire car is a real pain considering i live in ny and its cold out so what im going to do is connect the 4x6 speaker, and the 6x9's to the oem amp and just run the 4-6.5 components to the 4 channel amp, im sure it should sound pretty loud , cuz u figure once i change the speakers and use a louder radio it should actually sound a bit louder with the oem amp, then what it use to (this is in reference to connecting the 4x6, and 6x9's)
  7. #22
    Nov 2005
    queenz NY
    35
    ok now another question i have is in order to run the wire harness from the back to the front, where do i even find all those wires? and what gauge would they even be ? would they be like a 16,18 or 20 ?
  8. Remove Advertisements
