94-99 Deville Radio Wiring Diagrams Available
Results 1 to 14 of 14
Cadillac Audio, Video and Security Systems Discussion, 94-99 Deville Radio Wiring Diagrams Available in Item Specific Cadillac Discussion; Just thought id let everyone who wants to put an aftermarket deck in their 94-99 Deville that I managed to ...
    Slick Black Cadillac's Avatar
    Slick Black Cadillac is offline Cadillac Owners Fanatic
    Aug 2003
    Oshkosh, WI
    34
    137
    Just thought id let everyone who wants to put an aftermarket deck in their 94-99 Deville that I managed to upload the wiring diagrams neseccary for that install. Go to the pictures section and type in "Wiring Diagrams" as a key word search.
    Greencaddy98 is offline Cadillac Owners Member
    Sep 2003
    FL
    34
    37
    Re: 94-99 Deville Radio Wiring Diagrams Available
    [/IMG]wiring diagrams[IMG]
    Quote Originally Posted by Slick Black Cadillac
    [IMG]
    AshTray700 is offline Cadillac Owners Member
    Automobile(s): 1998 Sedan DeVille
    Nov 2006
    Jackson, MS
    37
    i dont see them, can you email them to ashtray700@aol.com
    Rantaholic is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2008
    3
    Hate to raise a thread from the dead, but are theses available? I need one for a 99 Deville.
    Thx
    Ian
    hnettles's Avatar
    hnettles is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac DTS
    Jun 2005
    Houston, TX
    66
    65
    Quote Originally Posted by Rantaholic View Post
    Thx
    Ian
    Did you try following the instructions in the first post (above)? I just tried it, and it worked for me. Not exactly the sharpest or highest-definition images, but a lot better than nothing, and my thanks to the original poster.
    rjohannsen is offline Cadillac Owners Member
    Oct 2008
    1
    Hi there,
    I can't seem to find them. Where is the "pics" section? I see Photo Albums..Is this it? When I search,for "wiring diagrams" I just returned to this thread.
    Confusedly yours,
    ptlbak is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac Concours DEVille
    Apr 2011
    54
    12
    Help. Pictures???? do you mean albums. I can't find them either.
    baller95's Avatar
    baller95 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 Cadillac STS-V Black On Black
    Jun 2010
    Toronto, Canada
    26
    1,344
    Here the wiring diagram for a 99 Deville -
    Car Radio Battery Constant 12v+ Wire: Orange
    Car Radio Accessory Switched 12v+ Wire: Yellow
    Car Radio Ground Wire: Black
    Car Radio Illumination Wire: Gray
    Car Stereo Dimmer Wire: Brown
    Car Stereo Antenna Trigger Wire: Pink
    Left Front Speaker Positive Wire (+): Tan
    Left Front Speaker Negative Wire (-): Gray
    Right Front Speaker Positive Wire (+): Light Green
    Right Front Speaker Negative Wire (-): Dark Green
    Left Rear Speaker Positive Wire (+): Brown
    Left Rear Speaker Negative Wire (-): Yellow
    Right Rear Speaker Positive Wire (+): Dark Blue
    Right Rear Speaker Negative Wire (-): Light Blue
    dingnasty is offline Cadillac Owners Member
    Automobile(s): 1998 cadillac deville
    Aug 2013
    32
    1
    Where is a 1998. I only have 1 yellow.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    Is this the same type of info that crutchfield has on their site?
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    The wiring colors seem to be inacurate...I don't remember Cadillac EVER having 2 power wires for the HU(during this period):
    Car Radio Battery Constant 12v+ Wire: Orange - IT IS NOT CONSTANT
    Car Radio Accessory Switched 12v+ Wire: Yellow - THERE IS NO SUCH SIGNAL
    Car Stereo Dimmer Wire: Brown - DIMMER+ILUMINATION is the same GRAY wire.
    Car Stereo Antenna Trigger Wire: Pink - INCORRECT COLOR
    Then the audio wires...is it BOSE is it Base? - BIG DIFFERENCE
    The above colors match the base cars.BOSE cars don't have the same signals (you have low level left/right and chime) only up to the RIM.
    This seem to be to me the color code of an aftermarket harness, not the car harness.
    '94-'95 and '96-'99 had TOTALLY different sound systems so you can't possibly have a diagram covering '94 to '99.
    The wiring was the same '94 and '95 or between '96 and '99, if you have '99 then you have any year down to '96 and so on.
    Be careful with information found on Internet, is not always accurate.
    If you don’t even know what is the difference between base and BOSE then my advice is to leave it alone.
    AngieK's Avatar
    AngieK is offline Cadillac Owners Member
    Automobile(s): 99 Deville Concours
    Aug 2014
    West Central Wisconsin
    24
    Re-resurrecting this thread once again...
    99 Deville Concours NON Bose radio. I need a confirmed radio diagram (the one above is not correct I have no pink wire in the dash) I am desperate for a diagram of the radio wires because...
    The previous owner cut off and threw away the original radio plug. I have the wires in the dash and a new GM 32 pin plug to put on, but I need to know what pins on the plug the original wiring goes to. I am trying to re-wire the original head unit back into this Cadillac nightmare car.
    AngieK's Avatar
    Aug 2014
    24
    Here are the wires that exist in my dash;
    3 "bundles"of wires. first is green, green with a stripe, and a bare wire. next is a tan, dark green, and a bare wire. last is a purple with a stripe, a dark blue with a stripe, and a bare wire.
    After that, "loose" wires (not bundled) are black possibly with a stripe ( i need to look closer in daylight), black, dark green, green, heavy-gauge orange, orange with a stripe, purple, purple with a stripe, and a gray.
    What I really need is a guide for what pins (E 1-15 and F 1-15) that these wires connect to, to match what the radio expects.
    I think the purple and purple striped is the data link and they go to F6 and E6, but I'm not sure which is which to what pin.
    There are no brown or pink wires that were cut, so every other diagram or color guide I have seen posted must be for the Bose version, that I don't have.
    Help?
  16. #14
    integraguy93 is offline Cadillac Owners Member
    Automobile(s): 95 Deville
    Feb 2016
    33
    1
    Here is a really good wiring diagram for the deville that has active radio with amplifier. I had a really hard time finding this, Hope this helps others.
  17. Remove Advertisements
