Wiring diagram
Results 1 to 2 of 2
Cadillac Audio, Video and Security Systems Discussion, Wiring diagram in Item Specific Cadillac Discussion; If anyone has a stereo wiring diagram for a '02 Seville SLS, can you please post it here, or e-mail ...
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Wiring diagram
    If anyone has a stereo wiring diagram for a '02 Seville SLS, can you please post it here, or e-mail it to me? I am installing an aftermarket unit, and need to know what the factory wiring entails. Or, if someone can lead me to a website, where I can view this info, it would be greatly appreciated. Thanks
    Don
    Hairball's Avatar
    Hairball is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Seville (base model)
    Nov 2010
    Tacoma, WA
    58
    160
    Re: Wiring diagram
    Did you ever find one? If so, could you share it with me? I have a 93 Seville and need to rewire the entire aftermarket stereo that someone put it using nothing but electrical tape! They had it wired so wrong the left speakers don't work, the power antenna isn't hooked up, and all the factory harnesses are cut. I found 2 diagrams for the 93 Seville but they are both incorrect. This is what they show:
    Battery Constant 12v: Orange
    Accessory Switched 12v: Yellow
    Ground: Black
    Illumination: Gray
    Dimmer: Gray/Black
    Antenna Trigger: Pink
    Left Front Speaker Positive (+): Tan
    Left Front Speaker Negative (-): Gray
    Right Front Speaker Positive (+): Light Green
    Right Front Speaker Negative (-): Dark Green
    Left Rear Speaker Positive (+): Brown
    Left Rear Speaker Negative (-): Yellow
    Right Rear Speaker Positive (+): Dark Blue
    Right Rear Speaker Negative (-): Light Blue
    But this is NOT what mine are! The only ones I have for sure are blue ones. I did find the factory power, ground, and memory wires but nothing else. There is no pink wire, there are 3 gray wires, and several yellows, etc. Things just aren't adding up. Thanks.
