Help with Bose problem on 99 STS
815 views 3 replies 2 participants last post by  Seafunk99
I just noticed the other day my passenger side speakers stopped working...until I hit a big bump in the road and they went back on for a while. Obviously there is a loose connection somewhere. Is this a common problem on ~99's? Do you think this is a connection at the head unit or speakers...its not one but all on the passenger side.
Oh, I should mention that if I just tap the rear passenger window button one click the speakers will work fine. As soon as the window is put up, it goes out again??
#3 ·
That makes sense...the reason I posted is becaue I don't know how the system is set up, wired, etc. Are the passenger side speakers are all wired together, so if one doesn't work, the rest won't either?
Also, what are the speakers on the dash? Two tweets and a regular speaker in the middle?
Thanks.
