Aftermarket Stereo installation Seville 2001 bose system sound
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Like Tree2Likes
Cadillac Audio, Video and Security Systems Discussion, Aftermarket Stereo installation Seville 2001 bose system sound in Item Specific Cadillac Discussion; Hi all I replace my Seville 2001 oem sound system ( Bose system sound) withe Aftermarket Stereo the problem is ...
    power007 is offline Cadillac Owners Member
    Automobile(s): STS 2001
    Jun 2011
    43
    ExclamationAftermarket Stereo installation Seville 2001 bose system sound
    Hi all
    1-the security system turn on
    2-Doors do not close
    3-Remote don't work
    What to do please help
    txtaz is offline Cadillac Owners Fanatic
    Automobile(s): 72,92,02 Eldorado
    Jan 2013
    55
    185
    Re: Aftermarket Stereo installation Seville 2001 bose system sound
    What interface did you use?
    "Doors do not close" - Really? Where did you install the HU, on the door jamb? Seriously, that door was wide open.
    What remote? Car alarm/door locks or stereo?
    Taz
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,857
    The OP is in Saudi Arabia.
    power007, The original Bose sound system is part of the car's serial data bus, TheftLock, and remote operation systems. You must obtain a special jumper harness and wiring in order to regain all your car functions.
    Search further through this Audio forum.
    Jan 2013
    55
    185
    Quote Originally Posted by Submariner409 View Post
    Ahhh, my bad. Appology to the OP. I cannot see location information as Sub can.
    You can also short out E6 and F6 on the GM32 plug to get everything "talking" again. I've testing it and it does not throw an error on my '02 ETC with Premium Bose.
    Taz
    vincentm, power007 and power007 like this.
    Jun 2011
    43
    Quote Originally Posted by txtaz View Post
    Taz
    it ok bro
    but can you please Explain it by picture
    Do you please guide me on the link
    Jan 2013
    55
    185
    Here is a picture.
    Your connector should be the same as mine. This is the one you removed from the original head unit. E6 and F6 are the serial data pins. If you did not use an aftermarket interface, you can short these out and the rest of your data bus will work again. Alarm/remote/door locks etc.
    What did you do for amps and speakers?
    I ask because you can cause damage to the system if you try and tap into RIM without an interface or knowing how to do it.
    Without an interface you will loose OnStar and chimes.
    Hope this helps,
    Taz<-- Off to tear the car apart one last time. Stereo time for me also.
    Jun 2011
    43
    Here is a picture.
    Attachment 104758
    Hope this helps,
    God bless you Thanks
    DRJEKYL_97 is offline Cadillac Owners Member
    Automobile(s): 1998 Deville
    Oct 2011
    El Paso, TX
    Taz
    Hello, I'm going to do an aftermarket stereo on my 98 Deville. When you say :short out pin E6 and F6 what do you mean? How do you "short out" the pins?
    Thank you..
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Connect pin E6 and F6 together.
    Normally is not required (due to the layout of the data bus consisting of loops) but should you have a bad contact in the same loop and the modules in between the bad contact and the NO contact (the gap you made by removing the perfectly functional OEM HU) will be out of data.
    To be honest (and I this is truly a friendly advise) the sound system in these cars is quite complex, if you ask the question “How do you "short out" the pins?”, probably is better to either leave it alone or ask for professional help. By professional I don’t refer to a person installing all day long aftermarket sound systems in Honda Civic and similar cars, somebody that has a very good understanding of the Cadillac sound systems (including access to schematics) and very strong background in electronics.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    RPO code for my Caddy's radio is UW7, my alldata doesn't match up, Ive a pink wire in F3 and the rear speakers are connected a ylw/red and black/brown wires
    I think it's covering a UW6, which i dont think matches up to mine..
    Jun 2011
    43
    thinks all for help me but another problem
    (Alarm bell) does not work after i replaced my oem sound system ( Bose system sound) withe Aftermarket Stereo
    so what can i do is there any Solution
    grateful all for you help
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    You need to use the correct integration module, as posted earlier in the thread. A Metra GMOS-06.
    Jun 2011
    43
    Is it easy to install with the 2001 STS Seville system and can you pleas guide my the way to install or in my 2001 STS Seville
  16. #14
    Jun 2011
    43
  17. #15
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes.
  18. Remove Advertisements
