After market amp in 2002 deville
Results 1 to 6 of 6
Cadillac Audio, Video and Security Systems Discussion, After market amp in 2002 deville in Item Specific Cadillac Discussion; Ok I want to hook an amp in my deville. I have everything figured out but a 5 volt source ...
    jubylives is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    82
    Ok I want to hook an amp in my deville. I have everything figured out but a 5 volt source to turn the amp on. Anyone have an idea where or if there is a 5 volt source?
    jeremy
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    You can try tapping into the rear fuse panel.. but not sure if the voltage meets or exceeds 5
    Nov 2007
    82
    I messed around back there but didnt find a 5 volt yet. I got through half of the fuses before I had to stop but still have more to check.
    Nov 2007
    82
    any ideas?
    stickpony is offline Cadillac Owners Member
    Aug 2005
    82
    Re: After market amp in 2002 deville
    why does it have to be 5volts? every aftermarket amp ive ever used had a 12v turn on signal?
    Dregun is offline Cadillac Owners Member
    Jan 2013
    38
    4
    Sorry to bring up an old thread, but this might be useful for others ..maybe..
    This device does a lot of things, but what you want it to do is take a signal coming from a speaker source (something with lower wattage..like your rear speakers, not your subs hooked up to a 2000watt amp!) Anyways, you feed this device 12v (from your amp) and ground (from your amp) hook up the Green wire to the negative terminal on one of your speakers and the blue wire from this will now function as your 12v remote on wire.
    As stated, this thing can do many things but it can also do what you are looking for without being to invasive.
    Pac Tr7
    Good Luck
  9. Remove Advertisements
