I have a 97 Eldorado
Results 1 to 10 of 10
Cadillac Audio, Video and Security Systems Discussion, I have a 97 Eldorado in Item Specific Cadillac Discussion; I have took out my bose hu and put on a boss in dash dvd player used gmrc-03 class II ...
    datdude61's Avatar
    datdude61 is offline Cadillac Owners Member
    Automobile(s): 04 Deville DHS
    Feb 2012
    Merritt Island Florida
    64
    I have took out my bose hu and put on a boss in dash dvd player used gmrc-03 class II data bus interface it works fine changed all speakers also put an amp in also but the only thing that seems to not work is that every time I cut the car off everything I just set like radio stations and also volume, bass, treble etc. all gone back to boss factory settings really annoying can someone please help a brotha out
    datdude61's Avatar
    Feb 2012
    64
    Can anyone help me help me please
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Re: I have a 97 Eldorado
    Your memory wire needs to be connected to a constant.
    datdude61's Avatar
    Feb 2012
    64
    Yeah I did that hell I went into the battery storage mode cut it off to see if that would help and no that didn't work either I just don't know
    theronw68 is offline Cadillac Owners Member
    Automobile(s): 1996 Deville
    Sep 2011
    39
    1
    I was having the same problem in my car. I ran a wire back to the fuse box and bought a little add-a-fuse thing. I cant remember which fuse I hooked in to, but, I no longer have that issue. I tried
    several different ones before I got one that worked(my test light broke and didn't feel like going back to the parts store.) Hope this helps.
    T.
    still_walkin's Avatar
    still_walkin is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Cadillac deville sedan 1986 cadillac deville RIP
    Apr 2007
    san diego
    33
    1,498
    its a red wire i believe on your HU which is your contsant it needs to be connected to a 12v source thats keeps getting 12v after the car is off. so either tap into your fuse box or check your wiring.
    datdude61's Avatar
    Feb 2012
    64
    Hey sorry to inconvience u but when I tap into fuse box which fuse do I tap into and do I connect wire to memory constant wire
    datdude61's Avatar
    Feb 2012
    64
    Apr 2007
    san diego
    33
    1,498
    Tap into a fuse that has a 12v when the ignition is in the off position .hazard lights fuse is a good one to pick
    datdude61's Avatar
    Feb 2012
    64
    Yes that worked thanks for ya help man
  13. Remove Advertisements
