seville indash cd
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Like Tree2Likes
Cadillac Audio, Video and Security Systems Discussion, seville indash cd in Item Specific Cadillac Discussion; i have 96 seville bose setup with cd-changer in trunk. will a 98 in-dash cd unit install ok? i could ...
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    seville indash cd
    i have 96 seville bose setup with cd-changer in trunk. will a 98 in-dash cd unit install ok? i could live without a cd changer function. actually i want to only use the in-dash cd function on the newer unit. i found a 96 and 98 in boneyard with intact systems. i do not know if they work but the head unit size seems to match. both dash/consoles have not been touched yet.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: seville indash cd
    YES it will work just fine as long as you have the VIN cleaned from the replacement HU. This is done ONLY with a TECHII tool (usually dealers have it).
    It will cost you around $50, takes about 5 minutes and you have to provide to the dealer a LEGAL proof of purchasing of the replacement HU. In this paper should be stated the name of the seller and the donor vehicle VIN. Otherwise a dealer won't touch the unit (is a matter of protecting us from people stealing the HU). If you have trouble with the dealer telling you that it won't work as '96 never had that unit see my Stock to BOSE conversion thread. I explained in there in one of the posts what they are suppose to do (in a nutshell: set the TECHII as if is connected to a '98+ car not a '96).
    Aug 2007
    mpls mn
    2,528
    Will the cd changer still function with my plan? I looked in trunk of 98 and did not see a changer or wiring. I can live without changer. Why do I want in car cd function? Bored I guess. And no one else will have a 96 Seville with factory Bose in dash unit. Does donor unit work? Am sure yard will give me credit on a doa unit. Now, how do I get the faceplate off and hu out?
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    YES, the existing CD changer will still work.
    There was no In-Dash CD unit available in '96 and '97, you need a '98+ unit.
    To remove the HU you need to remove the shifter knob, then pull up the wood trim (with the PRND321 on it), and disconnect the attached wires. Locate the 2 screws on the bottom of the ashtray and the one underneath the ashtray (you have to remove the tray to see it). Remove that and disconnect the harness then locate the 2 screws on the bottom of the Climate Control Module. Then you need to remove the piece on top of the HU with the INFO button on it (use a flat plastic tool inserted in a corner between the HU and pull up and out). Disconnect the harness and now you have access to the last 2 screws that hold the HU/Climate control assembly (the two are attached together with a bracket). Now you can pull out the two units and disconnect the harnesses (1 for Climate Control Module and 1 for HU + the Antenna cable). Once out you can separate the HU from the Climate Control Module and replace with the new one.
    Once everything is installed you are off to the dealer (with ~$50 in your pocket) and the proof of purchase of the replacement HU (that will get rid of the THEFTLOCK message).
    You can skip the dealer thing and save the $50 if you purchase a brand new (never ever, ever, ever installed in a car) HU. Again very important, not “like new”, note “brand new, tested works fine” it has to never been connected to a car.
    Before doing anything really make sure your existing unit is a BOSE otherwise won't work (even if the base and BOSE units look similar could not be more different inside). From your post I see you did not read the thread I recommended you, do that then take the next steps into this.
    B.T.W. the procedure is described many times on this forum, do a quick search and you can see it described in much more details including pictures.
    Aug 2007
    mpls mn
    2,528
    Lazy. I have factory cd unit from our grand prix sitting on shelf. But that's another story. Both units in cars say bose and my car is Bose so we are ok there. I wanted a quick answer. Got it. At least I am trying to stay with factory stuff.
    Aug 2007
    mpls mn
    2,528
    Junkyard guy said I can hook up 9v battery to hu leads and save memory so I don't have to clear theft code with tech2 tool. Ever heard off that? Have not pulled unit yet. Yes there is no battery in car now. But he said unit still has retained power? Huh?
    eldorado_97's Avatar
    eldorado_97 is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 STS, W/Nav
    Feb 2007
    Baldwin, Wisconsin
    26
    562
    the car communicates with the radio and your car knows your vin so when you turn on the car it looks at the current vin in the radio and if they are not matching then it will active theft lock... and actually it has a built in battery so it does remember the vin, so that it does not clear the vin when you disconnect it
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    It will be stupid and useless to have the VIN cleaned just like that.
    Remember the people working on junkyards barley have a high school (if that), be selective in who you listen for advises.
    Grand Prix is NOT Cadillac so it won't work.
    eldorado_97 and eldorado_97 like this.
    Aug 2007
    mpls mn
    2,528
    yes i know grand prix unit will not work/fit in my caddy. sort of a side comment that i had a gm indash cd unit but i need a proper one from a caddy. i look at many craigslist ads and found a few bose systems for caddys but prices were higher for the hu and seller was trying to unload entire system where i only need hu.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Contact ponyboyt he has like 10 BOSE HUs sitting on the shelf.
    Ebay has tons of these HUs for under $30.
    Aug 2007
    mpls mn
    2,528
    There is boneyard 4 miles from my house with several good cars. Actually it is pretty easy to find these units. Might go there today. Supposed to be 65f which is awesome for march in MN.
    Aug 2007
    mpls mn
    2,528
    The 98 unit does not say Bose. It has no signal processing buttons either. So that means it will not work in my 96 Bose equipped car? Could have sworn it said Bose last time I looked at it. The 2nd car, 96 also does have a Bose unit which is identical to my car.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    BOSE with BOSE, base with base, can't mix them. If it doesn’t say BOSE and is '98-'01 then is NOT BOSE.
    BOSE has a DSP button and a yellow RDS logo near the RDS button (yellow rectangle) plus the BOSE logo on the bottom left side of the screen
    Here is a detail of the screen with the BOSE logo on the bottom left.
    The theftlock logo is what tells you is a '98+ unit.
    A white RDS logo tells you the unit is '02+ (not compatible for you).
    Here is a simple diagram of the BOSE sound system
    note how the central piece of the audio system is the RIM NOT the HU, the HU and the CD changer as just auxiliary devices.
    And here is the simple diagram of the base sound system
    The HU is the central part of the sound system, the CD changer connects to the HU, and so do the speakers.
    NTL1991 and NTL1991 like this.
  16. #14
    Aug 2007
    mpls mn
    2,528
    Guy on eBay has 98-01 Bose units for 27 with free shipping. He has pic of unit With yellow rds buttons. I asked him and he said they will not work on 96-97 cars.
  17. #15
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    As I pictured my car, it clearly work in '97 (and '96 too), just that the '96 and '97 HAS TO BE BOSE.
  18. Remove Advertisements
