Trying to wire radar detector into mirror - '03 DeVille
Results 1 to 4 of 4
Cadillac Audio, Video and Security Systems Discussion, Trying to wire radar detector into mirror - '03 DeVille in Item Specific Cadillac Discussion; I want to mount a radar detector and utilize a switched power lead from the mirror harness. The harness connector ...
    Mojo88's Avatar
    Mojo88 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 White Diamond DeVille 'Base'
    Dec 2011
    Newport, RI
    65
    347
    I want to mount a radar detector and utilize a switched power lead from the mirror harness. The harness connector is a double row of about 18-pins (I didn't count the holes). Just wondering if anyone has done this on a 2003 DeVille and which wires did you use?
    Thanks for any help......
    Dave in RI
    Mojo88's Avatar
    Dec 2011
    Newport, RI
    65
    347
    Re: Trying to wire radar detector into mirror - '03 DeVille
    No one can help me get a 12 volt switched lead and ground?
    still_walkin's Avatar
    still_walkin is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Cadillac deville sedan 1986 cadillac deville RIP
    Apr 2007
    san diego
    34
    1,498
    Well I don't know your deville but for the switched 12v u can tapp into a fuse line and install a switch on it unless u wanna put a relay on it u can. As for a ground ur mirrors housing should be all plastic so you might want to use ur door behind the panel as a grounding point
    Mojo88's Avatar
    Dec 2011
    Newport, RI
    65
    347
    Thanks, but I got out my volt meter and found two suitable 12v wires.
    All set, thanks
  7. Remove Advertisements
