Sometimes dead radio
Results 1 to 7 of 7
Cadillac Audio, Video and Security Systems Discussion, Sometimes dead radio in Item Specific Cadillac Discussion; '87 DeVille radio with slide-equilizer and 8-track player. Good radio with no problems until recently. When radio turned On, left ...
    Dave S Texas's Avatar
    Dave S Texas is offline Cadillac Owners Enthusiast
    Automobile(s): '87 Coupe DeVille 4.1L FWD(New engine '08) 1981 F100 '03FXDL
    May 2008
    Austin(area), Tx
    73
    876
    Good radio with no problems until recently. When radio turned On, left side speakers front/rear are dead. Sometimes after no specific time, the left side comes on and all is well until the next time I turn it Off. I don't use the tape player, so I don't know if the same problem exists with it. I've never messed with it, so it's not something I did. Ideas where to look for trouble? (Sure like a push-button radio)
    Thanks
    May 2008
    Austin(area), Tx
    73
    876
    Re: Sometimes dead radio
    hmmm....if no one knows what might be going on with this radio, might anyone know of a replacement radio for this year DeVille or a place to look for replacement? I don't want one that requires a remote to operate. Have one like that in my truck and it is a pita to deal with just to change channels to pre-sets.
    I'd really rather get the OE radio to work properly again tho....
    Thanks
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,477
    Dave sounds like the connection to speakers might be bad. Radios are a dime a dozen in these cars at the salvage yard. I can look, think the same part number was used up to 93. You have the Symphony Sound, correct? You might just want to check the connections on the back of the radio to see if the problem is there. Remove the glove box to assist getting the radio out. you will need to remove the antennae coax before pulling the radio out. The trim on yours is held with a couple of screws at the top. There should be 2 screws on bracket at the top of radio, pull ash tray out and is one screw holding on the bottom.
  5. #4
    STS_Seville_Hunter is offline Cadillac Owners Enthusiast
    Automobile(s): 91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
    Sep 2008
    DHS/Palm Springs, CA
    29
    675
    Capacitors on the circuit board are going out.
  6. #5
    May 2008
    Austin(area), Tx
    73
    876
    Radio cured itself! Hopefully it will stay cured.
  7. #6
    May 2008
    Austin(area), Tx
    73
    876
    False cure! Finally got around to dealing with this radio problem. 3 of the speakers are bad. 0-Ohms at each. Have 4 new ones on the way. Lasted 25+years so I can't gripe.....
    Dave
  8. #7
    May 2008
    Austin(area), Tx
    73
    876
    Installation of 4 new speakers was the fix.
  9. Remove Advertisements
