Cadillac Deville 2000 Factory Amp Bypass (Bose)
Results 1 to 2 of 2
Cadillac Audio, Video and Security Systems Discussion, Cadillac Deville 2000 Factory Amp Bypass (Bose) in Item Specific Cadillac Discussion; I just have a quick question on if this will work, as how I'm thinking it will work. Can I ...
    someone1 is offline Cadillac Owners Member
    Automobile(s): None
    Nov 2011
    10
    QuestionCadillac Deville 2000 Factory Amp Bypass (Bose)
    Can I use this wiring harness http://www.google.com/products/catalog?q=cadillac+deville+amp+bypass+harness&hl=e n&client=firefox-a&hs=pxu&rls=org.mozilla:en-USfficial&prmd=imvns&bav=on.2,or.r_gc.r_pw.,cf.osb&b iw=1440&bih=770&um=1&ie=UTF-8&tbm=shop&cid=10649128575442538781&sa=X&ei=piDTTq 6XK4e4twe4k5mvDQ&ved=0CFUQ8wIwAA#scoring=tp to run from the speaker side of the amp (if that doesnt make sense then I can try to re-iterate) all the way to my aftermarket head unit? I would like just to use my factory head unit's amplifier instead of the bose one for various reasons. (The problem I'm having is that the factory bose amp is amplifying the built in amplifier on my after market head unit causing it to distort at a relatively low volume, in term, not allowing me to get the best voltage out of the pre-outs for my sub.. If anyone has a better solution please feel free to share)
    Thanks!
    Analyzer52 is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Deville DTS
    Nov 2008
    33
    12
    Re: Cadillac Deville 2000 Factory Amp Bypass (Bose)
    Did these work out, I planning to do the same thing?
