Please help for install ipad in my Seville 99
Results 1 to 5 of 5
Cadillac Audio, Video and Security Systems Discussion, Please help for install ipad in my Seville 99 in Item Specific Cadillac Discussion; hi this is my first issue i found some Products so i need help how is it work and is ...
    power007 is offline Cadillac Owners Member
    Automobile(s): STS 2001
    Jun 2011
    43
    hi
    i found some Products so i need help how is it work and is it easy to install in my Seville 99 factory boss system sound
    1-
    http://www.shipsound.com/USA-SPEC-PA...er_p_7290.html
    2-
    http://pac-audio.com/productDetails....&CategoryID=36
    Jun 2011
    43
    Re: Please help for install ipad in my Seville 99
    no one
    still_walkin's Avatar
    still_walkin is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Cadillac deville sedan 1986 cadillac deville RIP
    Apr 2007
    san diego
    33
    1,498
    Is it a factory radio or aftermarket. If its aftermarket use a 3.5/RCA y adapter and plug the rcas into the HU aux input as for charging it you can use a cig charger to charge it. But if you want a clean install just get a cig charger take the cig part apart add a 10a inline fuse and wire it to constant 12v source on your fuse panel. Your hazards or radio/cig fuse could be an option too
    Jun 2011
    43
    No it Is it a factory radio oem . All that I want to run the iPod without cutting wires
    During my research the Internet and found this product is it good
    thinks for help
    http://www.ebay.com/itm/GM10AUXINPUT...180771&vxp=mtr
    01ssreda4 is offline Cadillac Owners Fanatic
    Automobile(s): 99 STS VIN 9
    Nov 2011
    170
    Thats a steep little joker. How would you command the cd changer input when the changer would no longer be hooked up?
  8. Remove Advertisements
