Extension cable to move cd changer from Center stack to another location
Results 1 to 7 of 7
Cadillac Audio, Video and Security Systems Discussion, Extension cable to move cd changer from Center stack to another location in Item Specific Cadillac Discussion; are there any extension cables or cords i can get without having to wire and figure out what pin goes ...
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    are there any extension cables or cords i can get without having to wire and figure out what pin goes where ?
    i just ordered a isimple unit the ISGM73 ipod-iphone integration but i don't want to loose my storage bins all 3 of them in the center stack
    so i want to mount the unit somewhere els but i would need to have a cord and plug that is an extension to run it somewhere els since the cd changer plug and cord is all routed into that one big harness line and tapped together
    i don't want to go opening that up and messing anything els up
    so anything i can do to rout it to the Glove Box or under the dash ?
    eldorado_97's Avatar
    eldorado_97 is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 STS, W/Nav
    Feb 2007
    Baldwin, Wisconsin
    26
    562
    Re: Extension cable to move cd changer from Center stack to another location
    I thought that unit didnt work with your nav? well anyways the one I had gotten came with an extremely long cable, so i ran it to my glove box no problem and mounted the module underneath the radio itself in the dash
    ThumperPup's Avatar
    Mar 2009
    37
    7,696
    Quote Originally Posted by eldorado_97 View Post
    I spoke with Isimple i called them talked to there tech support they said the ISGM73 will replace the CD changer so basically the only wya it will work with the factory nav they told me i could not hard wire it in behind the deck it had to be plugged into the CD Changer they said who ever said it won't work doesn't know what they are doing
    they said i have any problems call them and they will help out might be a jumper issue on the mo dual
    But with the CD changer plug all warped up in that main harness that runs aground the floor under the console and all i don't want to put it there i wan tto put the Modual int he GLove box but i don't know how i would get a cable that would run i guess i need to get the Connectors and pin a cable myself that will let me route the cd changer or isimple unit to the glove box
  5. #4
    Feb 2007
    Baldwin, Wisconsin
    26
    562
    Well I hope it works for you but the Navigation uses the class 2 data to control the cd changer and the isimple only reads the old anaolg signals i thought.. but I dont know if it works thats great please update me on that, but I still dont believe it will work.
  6. #5
    Feb 2007
    Baldwin, Wisconsin
    26
    562
    Oh and now that i think of it there is an adaptor cable that runs from the stock harness to the isimple module, you could just cut and extend those wires if thats an option that would be a piece of cake then.
  7. #6
    ThumperPup's Avatar
    Mar 2009
    37
    7,696
    Im not sure im understanding what your saying
  8. #7
    Feb 2007
    Baldwin, Wisconsin
    26
    562
    The ISGM73 does not plug directly into the cd changer plug it has an adapter that it comes with, if you just extend that adapter then you will be fine
  9. Remove Advertisements
