Amp+ Sub(s) combo question
Results 1 to 10 of 10
Cadillac Audio, Video and Security Systems Discussion, Amp+ Sub(s) combo question in Item Specific Cadillac Discussion; Just purchased a 2nd Kicker Comp 10C104 sub (150w rms) to add to my existing one, which is currently powered ...
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Just purchased a 2nd Kicker Comp 10C104 sub (150w rms) to add to my existing one, which is currently powered by a Kenwood KAC-5204 2 channel Amp:
    http://www.crutchfield.com/p_113KAC5...ures_and_specs
    Will this still be enough for them? Or should i upgrade, and if i decide to use this, i'm thinking of wiring them in parallel 4+4 = 2 ohm. Will this push the amp too hard?
    I'm planning on a vented box. Might go sealed. I dont want my car to rattle.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    OffThaHorseCEO is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS Premium 3.6, 1989 Allanté
    Jul 2005
    Fayetteville NC
    33
    4,513
    Re: Amp+ Sub(s) combo question
    your amp list 2ohm as a compatible spec.
    you COULD run them both off the amp, assuming your wiring and charging system is in good shape, youd be seeing about 70w/each. thats not really that bad, but its not gonna be a block quaker or anything like that.
    If you upgrade, what would you upgrade to?
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    If i do i'll most likely go Kicker as well Perhaps something like this:
    http://www.sonicelectronix.com/item_29816_Kicker-DX400.4-11DX400.4.html
    N
    ot looking to vibrate house windows, just a little more oomph, i also wanna wire my door and rear shelf speakers to a seperate amp.
    Jul 2005
    Fayetteville NC
    33
    4,513
    that amp wired right would probably be almost perfectly matched to those speakers.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    So should i wire as
    sub(4ohm) - sub(4ohm) - to > amp -
    + + to > amp + ?
    In parallel?
    Jul 2005
    Fayetteville NC
    33
    4,513
    that made no sense haha, the amp you listed is a 4channel bridgeable. the terminals are the bottom left on this pick, and they are stacked front is prob on top rear on bottom
    note: the red and black wires on the top speaker do not need to cross or splice, that was just the way i drew it
    so instead of using 4 channels to power 4 speakers, youll be using 2 channels each speaker. according to the specs, this will give you about 140 watts RMS
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    Here's the terminals on my amp
    Jul 2005
    Fayetteville NC
    33
    4,513
    o i thought you were upgrading. in that case
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    Thanks man, much much appreciated, now i have know how for my current and a future amp if i upgrade, thanks!
  13. Remove Advertisements
