Yesterday started just turning on and off every 3-4 seconds, when the Nav/radio screen comes on for those 2-3 seconds it shows the time, Date and which driver key unlocked the car and it does track back and forth between key #1 and #2. Also for the last 1-2 seconds you get sound from whatever CD was playing last then it shuts off and you get two beeps, then in 1-2 seconds it turns on again. In the "on" time frame none of the buttons will do anything but as I recall during normal initial start up they did not do aything for the first 4-5 seconds anyway so that may just be a time delay issue. Does this sound like the amp failing or ???
Update:
Pulled AMP fuse and it continued to turn on and off, just could not hear the amp power up anymore.
Pulled Audio fuse and still continued to turn on and off
Pulled the NAV fuse and then it stayed off
Replaced the amp and audio fuse and it still stayed off
Does this point to a Dav nav DVD player ?? or ??
Update:
