NEED HELP with aftermarket sub and amp PLEASE HELP!
Results 1 to 3 of 3
Cadillac Audio, Video and Security Systems Discussion, NEED HELP with aftermarket sub and amp PLEASE HELP! in Item Specific Cadillac Discussion; i just recently purchased a used 2002 DTS and the rear factory sub was blown...i cut the wires! and thought ...
    816rider is offline Cadillac Owners Member
    Automobile(s): 2002 STD Deville
    Apr 2011
    41
    43
    i just recently purchased a used 2002 DTS and the rear factory sub was blown...i cut the wires! and thought i would wire in a LOC and some aftermarket subs, and an amp little did i know this would be some HUGE ordeal...i have undid everything i thought was right, and just wired the sub back the way it was, and the stereo still will not work...i would like to still add this aftermarket set up if possible...I am using the stock head unit and stock speakers (minus the blown sub) PLEASE HELP!
    Apr 2011
    41
    43
    Re: NEED HELP with aftermarket sub and amp PLEASE HELP!
    Quote Originally Posted by 816rider View Post
    i forgot to say this is a STD without the BOSE setup...hope this is enough info, and i will continue to check this site looking for answers...glad i found this site, im sure you guys will be pretty helpful!
    baller95's Avatar
    baller95 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 Cadillac STS-V Black On Black
    Jun 2010
    Toronto, Canada
    26
    1,344
    So basically, you cut some wires in the back for the factory sub and now your factory head unit isn't working?
