Results 1 to 7 of 7
Thread: Two 12's In A 2003 Cadillac DTS
    Trivium is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac DTS V8 4.6L
    Nov 2010
    25
    65
    So basically heres the deal I Own a 2003 cadillac DTS and i wanna throw two 12's in it.
    I Do have Bose's So it does have the 300w amp to power the 8 inch sub woofer.
    how would i take the signal from the 300w amp and connect it to my 1800w. and wire the subs n Power , Ground ect.
    Can anyone help me
    OffThaHorseCEO is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS Premium 3.6, 1989 Allanté
    Jul 2005
    Fayetteville NC
    33
    4,513
    Re: Two 12's In A 2003 Cadillac DTS
    battery is under the backseat, I wired my amps power and ground directly to that (fused of course.)
    my amp had a "speaker level" input harness that i wired to the sub in the rear deck and connected to the amp. This takes the place of the rca cable
    T-Millz312's Avatar
    T-Millz312 is offline Cadillac Owners Member
    Automobile(s): 2003 3.2L CTS Luxury Sport Package
    Mar 2011
    26
    21
    do you want the 8" sub to operate in addition to the 12s? or in place of it?
  5. #4
    Nov 2010
    25
    65
    no i just want to run the two 12's
  6. #5
    T-Millz312's Avatar
    Mar 2011
    26
    21
    Either way you'd have to get a different amp. something with more power for the 12s depending on their rms. I'd run power all the way from the battery under the hood not the one under the backseat. That way all 3 subs will run and give you a better range of highs from the stock Bose sub... I have heard of some people replacing the Bose sub with a 10" sub, but thatd require more custom work and you'd need a freeair sub due to the fact that it's not in a box.
  7. #6
    Jul 2005
    Fayetteville NC
    33
    4,513
    there is no battery under the hood, only under the seat
  8. #7
    baller95's Avatar
    baller95 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 Cadillac STS-V Black On Black
    Jun 2010
    Toronto, Canada
    26
    1,375
    @OffThaHorseCEO you're right there is only one battery under the seat, and you should keep the factory sub disabled because the air pressure from the 2 12's will mess up the way the 8 moves and will make everything sound like crap. I had 2 12's with the factory and it was ok, then i removed the factory and it was even better! I now have 2 10's and they bang a lot more then my 2 12's ! And did you hook up the factory sub wire (from factory amp to sub) to your amp speaker level input?
    Here are my 2 12's -
    ^ I now have 2 10's and these 12's have been put in my van, LOL yes my van!
  • You may not post replies
