Denso NAV 5 Pin Plug Pinout
Results 1 to 6 of 6
Cadillac Audio, Video and Security Systems Discussion, Denso NAV 5 Pin Plug Pinout in Item Specific Cadillac Discussion; Can some one help me out I am trying to figure out what wires go to this connector. I think ...
    Fast is offline Cadillac Owners Member
    Automobile(s): 02 Deville DTS
    Jan 2011
    34
    72
    PostDenso NAV 5 Pin Plug Pinout
    Can some one help me out I am trying to figure out what wires go to this connector. I think I'm sure of where 2 wires go but clueless to the other three. I was hoping that it was for sirius module. The two pins that I am sure of has to do with the Voice recognition for the navigation covering pin #1 and pin #5 any help would be greatly appreciated as I am so close to finish up everything that I wanted on the car.
    fleetwood96 is offline Cadillac Owners Member
    Automobile(s): 06 STS;05 DTS;03 STS;96 Fleetwood;95 Deville
    Sep 2003
    75
    Re: Denso NAV 5 Pin Plug Pinout
    Hi Fast - I have an 04 SLS service manual now and according to it the black C2 connector (5 pin) is only used for Microphone signal (pin 1) and "Drain" (pin 2). Pins 3-5 are not used. As far as XM radio is concerned, that module communicates with the radio/nav by means of the DATA wire and not through any sort of direct connection.
    By the way, I have gotten myself into trouble with my install - I decided to go ahead and clear the entire firmware (using the secret diagnostic screen under pin #6497). I was confident I could reload the firmware from one of my Loading.KWI files on my MAP version 1.1 and/or v3.0 DVDs. Well, I managed to clear the firmware just fine but it will not accept either firmware file (burned to a CD-R disk). I'm stuck at the "Load System disk" prompt that others have reported!! Perhaps these versions are too old (one says May 2001 and the other June 2002). My unit was made in Aug 2002 according to the label on top of the case.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Burn it on a different brand CDR and try various writing speeds (perhaps Writer units too).
    It could be finicky reading burned CDs...don't worry it will work eventually.
    brougham96 is offline Cadillac Owners Fanatic
    Automobile(s): 1973 Sedan deVille, 2004 White Diamond deVille DHS
    Mar 2010
    St. Paul, MN
    122
    To steer back to the OP a little bit... If I were to hook up a regular microphone to pin 1 and 2, would it work? It's just looking for mic level audio? I'm and audio/video tech, so I might have to "borrow" a small mic from work and see if the nav unit responds. The reason for this is I have a '99 without Cell Phone/Onstar option, so I don't believe I have the mic required for this.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    The mic is located on the console next to where the garage remote is (or the sun roof buttons if equipped). You can see a small grille in there. You can pull the plastic and check it out but I have seen it in a '98 STS w/o OnStar so something tells me should be in a '99 too but then there are always cost savings...
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    i think the mic your talking about was not just for onstar
    but i think they used it to handle the AVC auto volume controle on the bose equipped vehicles
    but i may be wrong
  9. Remove Advertisements
