2003 STS Unlock Nav while car in motion? How to?
Results 1 to 8 of 8
Cadillac Audio, Video and Security Systems Discussion, 2003 STS Unlock Nav while car in motion? How to? in Item Specific Cadillac Discussion; Hi, My wife would like to be able to enter our destination while I am driving and she is in ...
    kippjones's Avatar
    kippjones is offline Cadillac Owners Fanatic
    Automobile(s): 2005 ESV & 2008 Escalade
    Apr 2004
    208
    Hi,
    My wife would like to be able to enter our destination while I am driving and she is in the passenger seat. Is there a way/code/procedure to do this?
    Thank you.
    fleetwood96 is offline Cadillac Owners Member
    Automobile(s): 06 STS;05 DTS;03 STS;96 Fleetwood;95 Deville
    Sep 2003
    75
    Re: 2003 STS Unlock Nav while car in motion? How to?
    Yes! There's a secret unlock method for 02-05 Cadillac Nav units. If you hit the ROUTE button, there's a "hidden" in the lower right hand corner of the screen. Press & hold the corner for a few seconds and you'll see a diagnostic screen. My memory is a bit fuzzy as it's been awhile since I've done this, but one of the button allows you to enter a diagnostic code. Someone correct me if I'm wrong, but I'm thinking the code is 1753. Once you do this the full "ROUTE" ability will be active, even in drive, and you'll be able to play a regular DVD while in Drive as well.
    kippjones's Avatar
    Apr 2004
    208
    Very cool, I was able to get to the screen but I cannot find where to enter the code???
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    The music not key that is right above the on of and volume button press and hold in till key pad pops up
    code should be 1791 i belive but i heard that some of them had other codes
    kippjones's Avatar
    Apr 2004
    208
    Yes, that works for DVD playback but I can't get the nav to go when driving. Anyone know the right code for the nav????
    Thank you.
    kippjones's Avatar
    Apr 2004
    208
    Sep 2003
    75
    Seems I was getting my "hidden" techniques mixed up! That code is only for playing DVDs. Once in the DENO diagnostics screen (the one with a bunch of buttons) hit the RUN button and then there's some sort of OK button directly under the clock (you can barely see just the bottom of the button). With careful aim you should be able to press it instead of the clock. This should allow Navigation to work even at speed but only for the duration of this ignition cycle (it will reset once key is turned off)
    kjanks is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2008
    81
    CRAP! I hit the sound button and now i can hit the return button. it is more underneath the clock than the original screen when you just select run. HELP!! What do I do? Disconnect the battery?
  11. Remove Advertisements
