'99 STS UX9 Bose to Denso Nav conversion
Results 1 to 5 of 5
Cadillac Audio, Video and Security Systems Discussion, '99 STS UX9 Bose to Denso Nav conversion in Item Specific Cadillac Discussion; Okay, I'd like to tackle this project this winter, and I've heard it's possible. I am an audio/video installer by ...
    brougham96 is offline Cadillac Owners Fanatic
    Automobile(s): 1973 Sedan deVille, 2004 White Diamond deVille DHS
    Mar 2010
    St. Paul, MN
    122
    Question'99 STS UX9 Bose to Denso Nav conversion
    I am an audio/video installer by trade, although mostly in television production-type enviroments. So I'm pretty comfortable with a soldering iron, multimeter, etc..
    A couple questions regarding this:
    -Is it true the Nav unit will work with the currently installed RIM? If that's the case, I would assume there is no compromise in the sound quality of the Bose system.
    -Any issue with steering wheel controls? I know the '99 has a different control layout than the newer steering wheels, not sure if they are the same buttons. I guess I'm not sure if they run to the HU or the RIM.
    -I've heard somewhere that later models of the NAV unit are locked down a bit more as far as playing DVDs while driving (with unlock code).. Is there a year range I should try to find?
    -Just curious: Does the DVD player do 5.1 surround? I know the car has the physical speaker layout to make it happen, but not sure if the RIM could do it.
    and probably most importantly:
    -Does anyone have the pinout for the harness? I know i need to find a VSS signal, and add a GPS antenna, is that it?
    For the VSS signal, I see connector C200 at the cluster, pin A11, "Vehicle Speed Signal-4000 pulses per mile" is that what I need?
    And yes, I am aware I would need a flash from the dealer to disable Theftlock.
    Any help would be much appreciated. Thanks!
    Mar 2010
    St. Paul, MN
    122
    Re: '99 STS UX9 Bose to Denso Nav conversion
    Another question: What's the difference between the U3Q and U3R RPO's? Does it need to say 'Bose' on the front?
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    i have had both the ones that say Bose and the ones that dont say bose
    im not sure what the pro codes are for
    just as long as you get one of the navies from the 2002 - 05 deville or 2002 - 04 seville units it will work
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Both work, if I remember correctly up to gen. 3 it had BOSE while 3 and 4 have no more logo. There are minor differences between the units (like the override codes). If you have to chose between one with the logo and one with w/o logo go with the one with BOSE logo. Be sure if the unit sat for a while the firmware is blank so you will need the firmware. Also the CD changer you may have IS NOT compatible with the NAV unit, you need new CD changer (NAV unit compatible).
    Mar 2010
    St. Paul, MN
    122
    If I need the firmware, where can I get it? Is there an internal battery I can pull to clear out the Theftlock data? If I can save a trip to the stealership, I'd be all for it.
  8. Remove Advertisements
