Where to start, stereo not working 2004 Deville
Results 1 to 14 of 14
Cadillac Audio, Video and Security Systems Discussion, Where to start, stereo not working 2004 Deville in Item Specific Cadillac Discussion; I am picking up my new to me 2004 Deville tomorrow. The stereo does not work. The clock does, and ...
    Locomotive Breath's Avatar
    Locomotive Breath is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Nov 2010
    Jarrettsville, Maryland
    50
    138
    I am picking up my new to me 2004 Deville tomorrow. The stereo does not work. The clock does, and if you hit the tune button it says something about presets.
    Here is my RPO list from the decoder.
    http://www.compnine.com/vid.php?vin=1G6KD54Y24U256362
    Where do I start first, fuses? I wouldn't be opposed to putting an aftermarket stereo in, as I use a USB thumbdrive and my smart phone for a lot of my music needs, but I understand this could be quite the undertaking?
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: Where to start, stereo not working 2004 Deville
    Start with the amp fuse...
    Nov 2010
    50
    138
    Will do.
    Would that cause no stations to show up on the display?
    I am new to this as far as Cadillac goes, and I understand the HU is a central brain of sorts. Not as easy as pulling it and swapping in an aftermarket HU by any means from what I have gleaned from researching here.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Oh, in that case forget about the amp fuse, is the data wire. I would expect a "U" code in this situation (see the sticky here). The no display situation is caused by the fact that the HU cannot communicate with the DIM.
    Part of the HU startup procedure is to request the VIN from the DIM and compare it with the one stored in HU. If no match will not start (say you take the HU from one car and install it on another). But if you would have communication and the VIN will not match then the HU will display "Theftlock enabled". In your situation (if I understand correctly) you have no such message but you do have clock, is the clock always 12:00?
    If the clock does display the correct hour then you have communication, and that is a head scratcher...
    The only thing I could recommend is use a TechII tool (dealership ~$50 charge) and see if it the HU and DIM are responsive.
    Nov 2010
    50
    138
    I believe the clock does display 12:00.
    I am picking the car up in a couple hours.
    Nov 2010
    50
    138
    The clock DOES keep time. If I turn the ignition to on, and hit the power now the volume and station presets will come up, but then they go away and it's just the clock. I ejected a CD from the HU, still the same.
    It act like it is setting away and home presets, but nothing else.
    I couldn't get the ashtray open, someone had screwed it shut because it was broken.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    What are the codes? Look especially for "U" codes and anything under IRC.
    Nov 2010
    50
    138
    Quote Originally Posted by n*caddy View Post
    what are the codes? Look especially for "u" codes and anything under irc.
    irc u1000(c) u1016(h), and u1064(h)
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Is your data wires. You need to remove the HU (since is a Deville is a 1 minute job). Then you need to check your E6 and F6 wires.
    Do you have a wiring diagram for the car?
    Is not difficult to diagnose with the diagram at hand.
    You can use one the car's data port (underneath the steering wheel to the left) to connect either E6 or F6 HU pins, apply power and see if it starts. If it does then is a problem with the wires between the DIM and the HU. If it still doesn't then is either the HU (defective) or the DIM (or DIM connector).
    Nov 2010
    50
    138
    Quote Originally Posted by N*Caddy View Post
    I don't have a manual yet, so no clue how to remove HU, and no wiring diagram.
    Nov 2010
    50
    138
    Is there a write up on how to troubleshoot this? I need tunes!
    Nov 2010
    50
    138
    There is an update on my stereo situation in a thread I posted today.
    http://www.cadillacforums.com/forums...ml#post2452158
    num1bigguy is offline Cadillac Owners Member
    Automobile(s): 2004 deville dts
    Sep 2014
    38
    I realize it's been awhile but doesn't hurt to try. I am having a similar issue. To mix things up my radio starts working a few minutes after starting my drive. Everything else that it does is the same. No door chimes. Radio works a few seconds then displays only the clock. But the a few minutes after driving the radio comes on.
  16. #14
    Sep 2014
    38
    Quote Originally Posted by num1bigguy View Post
    Also it's a 2004 deville with Bose.
  17. Remove Advertisements
