Anyone run any RCA's from deck to trunk in 93 Seville?
Results 1 to 2 of 2
Cadillac Audio, Video and Security Systems Discussion, Anyone run any RCA's from deck to trunk in 93 Seville? in Item Specific Cadillac Discussion; If so, how long of length did you use? I searched all threads in both the Seville threads & Car ...
    Hairball's Avatar
    Hairball is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Seville (base model)
    Nov 2010
    Tacoma, WA
    58
    160
    QuestionAnyone run any RCA's from deck to trunk in 93 Seville?
    I searched all threads in both the Seville threads & Car Audio section for "RCA". Nothing came up, so I need to ask.
    I'm about to purchase a 6-channel RCA cable to run from just below my head unit (from an equalizer) back to the trunk to my amps) and need to figure out if 16ft would be long enough or 17ft or 19ft. I was planning on getting 19 feet just to be safe (it would suck to run short!) but I'm wondering if a shorter length would be more than enough.
    If anyone has run any RCA cables from the deck area to the trunk in a 93 (or so) Seville, please let me know how long your RCA cables were.
    Thanks much!
    still_walkin's Avatar
    still_walkin is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Cadillac deville sedan 1986 cadillac deville RIP
    Apr 2007
    san diego
    33
    1,498
    Re: Anyone run any RCA's from deck to trunk in 93 Seville?
    you r best bet is to run from the dash where the radio is just below the ash tray . run it along the plastic under dash then open the door remove the plastic lining of the door move the carpet go towards the back seat then to the trunk you should have to black vents in the lower left or right pull the wire thru there and you should be good. with a elderado a 16ft should be good but i usually go with the longest i can find because the car has many turns and tight spaces and the wire gets used quickly post any more question
