Will Bose Speakers Work
Results 1 to 4 of 4
Cadillac Audio, Video and Security Systems Discussion, Will Bose Speakers Work in Item Specific Cadillac Discussion; Fellows, My car is a 2001 Deville base model. I have been collecting Deville Bose speakers from the junkyard. My ...
    larry2010 is offline Cadillac Owners Member
    Automobile(s): 2001 Deville 105,000 miles
    Oct 2010
    60
    47
    Fellows,
    My car is a 2001 Deville base model. I have been collecting Deville Bose speakers from the junkyard. My car did not come with the Bose audio system. Would installing these Bose speakers in my car give me a quality boost in speaker sound?
    Thanks for all input. Larry
    ItalianMike's Avatar
    ItalianMike is offline Cadillac Owners Member
    Automobile(s): Cadillac Seville SLS
    Sep 2008
    Cape Coral Florida
    42
    9
    Re: Will Bose Speakers Work
    yes they will but they are rated 100 watts and 1 ohm if you crank it to loud with to much bass your radio lights will flicker and you may also burn out the head units amp but they do sound great and can be used
    Warspite's Avatar
    Warspite is offline Cadillac Owners Fanatic
    Automobile(s): 1962 coupe (selling), 1995 Seville SLS, 1966 Sedan DeVille
    May 2010
    Atlanta, GA
    57
    244
    The Bose speakers are 1 Ohm resistance, and are "full range" with no separate midrange or tweeter. Stock non-Bose speakers are 10 Ohm. The Bose system is designed to push low-level signal (2-4 volts) to each individual, speaker-mounted amplifier. Just an opinion, but you're probably best served by replacing the stock non-Bose speakers with a good 2 or 3-way aftermarket (Rockford Fosgate, Kenwood, et al) set, which is closer to the impedance of the stock units (most are 6-8 Ohms) which won't overtax the head unit. 1 Ohm, as in the Bose speakers, look close to a short circuit to an amp that is expecting 10 times that load.
    claymonds is offline Cadillac Owners Member
    Mar 2012
    38
    The 2000-2005 deville's have a trunk mounted Bose amp that powers all the speakers in the car. The non bose units also have a seperate trunk mounted amp in the trunk I beleave its a Delphi amp. None of the head units have build in amps, also both the amps communicate with the onboard computer.
  7. Remove Advertisements
