1997 deville upgrade from cassette to cd
Results 1 to 4 of 4
Cadillac Audio, Video and Security Systems Discussion, 1997 deville upgrade from cassette to cd in Item Specific Cadillac Discussion; I would like to swap out the head unit in my 97 deville to one that has a cd player. ...
    satdog75 is offline Cadillac Owners Member
    Automobile(s): 1997 Deville
    Sep 2010
    42
    15
    I would like to swap out the head unit in my 97 deville to one that has a cd player. mine is standard am fm cassette with NO cd changer. I have an intermittent short in my factory unit but want to keep steering wheel controls, etc so.......can i get a cd player head unit from salvage (factory), and just swap it out? if not, what options to I have?
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: 1997 deville upgrade from cassette to cd
    If your sound system is BOSE is a direct replacement. But keep in mind the CD units are only available after '98 (there was no In-Dash CD in '97) and the '98 units are theftlocked. It is not a issue, '97 cars can support this feature but you will have to take the HU (once installed in the car) to the dealer to clean up the VIN (or as is popularly called "unlock it").
    If your system is not BOSE then it is still possible, but it is EXTREMELY complicated (you will have to convert the car to BOSE - change all speakers, add 2 extra speakers, add one extra module called RIM, completely rewire the sound system in the car, add 2 relays and one extra fuse).
    Regardless if you have BOSE or not you can always add one 12 Disk OEM CD Changer (goes in the trunk). The car is already prewired for it, is a plug an play thing (the cost is less than $100 just look on e-Bay).
    TexasGuy is offline Cadillac Owners Member
    Automobile(s): Deville 97
    Jul 2010
    38
    84
    Can you post URLs to a few auctions? I don't want to buy a wrong thing... Please...
    Anyway to get MP3s to play through some AUX port?
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    First and foremost DO YOU HAVE BOSE?
    You can tell based on the small white logo in the bottom left corner of the screen. If it says BOSE with bold italic letters then you have BOSE and you can indeed update to a '98-'00 InDash CD BOSE HU.
    If you don't have the BOSE logo then you can't upgrade. I mean you could (I did it) but requires replacing every single module from your sound system (except the CD changer and the steering wheel controls), including all the speakers and the entire audio harness. Took me about 1 year to find all the parts and manufacture the harness, about 1 day (or less) to put all the stuff in.
    See my previous post about the additional cost involved for the Theftlock feature that '98+ HU have.
    If you don't have BOSE then your best option is to add a OEM 12 Disk CD changer (less than $70 on e-Bay).
    Here is the CD changer you need (ignore the price, should be 3 times less). But observe the magazine (you need that or is $40 at the dealer), and you also need the mounting stand/bracket thing. This unit does not have the correct stand for Cadillac.
    In this auction is a '96-'97 (ONLY) Seville/Deville/Eldorado Base stereo (the price is about twice the market price by the way).
    In this auction is a 96-97 (ONLY) Seville/Deville/Eldorado BOSE stereo. Compare it with the previous one, apparently are the same but notice the extra 2 buttons under the 3-4 and 5-6 buttons (DSP OFF and +Level-) plus the BOSE logo. They may look the same (mechanically are the same, they mount the same) but inside could not be more different, they are NOT compatible by many many miles. Again the price is ridiculous, the owner asks about 5 times the normal price.
    In this auction is a '98-'00 Seville/Deville/Eldorado BOSE InDash CD unit. This unit is 100% compatible with the previous one. Notice the Teftlock logo on the right side of the screen. That's how you tell is a '98+ unit (well that and the obvious CD slot not available between '96 and '97). Also notice the yellow RDS logo in the bottom right corner of the unit (next to the RDS yellow rectangle button).That's what tells you the unit is pre '01, after '01 the RDS logo is in the diagonally opposite corner. The price for this last auction is true for the shape of the unit, $40 is a MINT MINT one.
    Notice how I did not mentioned anything about Catera, stay away from those units, they look IDENTICAL but are not compatible, make sure is not Catera before purchasing. I am afraid you will endup buing the wrong unit as they look absolutely identical but inside could not be more diffrent. Also the adds are wrong, most of the people don't know what they sell, I would say about 40% are wrong (years and models), you really need to know what you need to buy.
    Better post a picture of your HU so I can tell exactly what you have, and then we go from there.
    Here is the CD changer you need (ignore the price, should be 3 times less). But observe the magazine (you need that or is $40 at the dealer), and you also need the mounting stand/bracket thing. This unit does not have the correct stand for Cadillac. The bracket/stand is available new at your GM dealer for less than $20 (so no big deal).
    AUX input I have solution for both base and BOSE cars. See the threads I posted about this subject.
  7. Remove Advertisements
