Results 1 to 4 of 4
Thread: 02 dts steering wheel controls going crazy
    mrgoodbar67's Avatar
    mrgoodbar67 is offline Cadillac Owners Enthusiast
    Automobile(s): 2002 Cadillac DTS Deville on Vogues and DTS Blades
    Jul 2007
    Bell, CA
    33
    605
    ok so every now and then and all of a sudden....(havnt found a pattern) the volume up button on the steering wheel turns the radio volume down and the volume down changes the stations.
    not all the time or permanently, but it happens then it goes back to normal all of a sudden.
    radio is factory and have not done any changes to it.
    anyone experience problems?
    btw i have the stock navigation hu.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: 02 dts steering wheel controls going crazy
    Does this happens when you turn your steering wheel?
    Does this affects the climate control too (like fan speed, temperature)?
    Any codes?
    Jul 2007
    Bell, CA
    33
    605
    no this only happens when i press the buttons....however, i repaired the issue.
    the connector for the steering wheel controls was not properly connected on the hu.
    all is well now.
  5. #4
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    There is no such connector, the steering wheel controls are connected to the DIM witch then sends the commands to the HU (and AMP if is BOSE) using the car data bus.
    Not sure what you fixed but as long as it works is all good
  • You may not post replies
