01 sls radio to touch screen install help
Results 1 to 4 of 4
Cadillac Audio, Video and Security Systems Discussion, 01 sls radio to touch screen install help in Item Specific Cadillac Discussion; I should be expecting a new 7in double din touch screen unit this week. Now before i start i was ...
    01sevillesls is offline Cadillac Owners Member
    Automobile(s): 2001 seville sls
    Aug 2010
    30
    29
    I should be expecting a new 7in double din touch screen unit this week. Now before i start i was just looking for some advice on what to do as far as the install without the gmos 6. I have installed plenty of aftermarket radios but never in a cadillac. After reading through some similar post's i realized its not all that simple. Now I understand that if i do not use the gmos6 adapter that i will have to keep my original radio installed in the car. So i figure i will run it to the trunk unless i settle for the glove box. So for me to install the new unit, will i just splice the wires and connect them onto the same lines already beeing used or what? And i do have the bose system and no need for onstar incase that may be a problem. Also what is it that i will be missing i hear the chimes will no longer work, does that mean for everything that chimes or just some?
    Aug 2010
    30
    29
    Re: 01 sls radio to touch screen install help
    anything? i just got it today and plan on doing the install tomorrow if i can
    80Biarritz is offline Cadillac Owners Member
    Automobile(s): 2001 Eldorado ETC, 1980 Eldorado Biarritz
    Sep 2009
    41
    20
    Get the GMOS-06. you don't want to be splicing into any of you stock wiring. Cadillac's are touchy like that and besides, the GMOS-06 has all the necessary wiring to make revers sensor work, brake sensor, chimes and warning tones, amp turn on, Antenna Turn on, dimmer, Mute, Nav, and Onstar tones and voice. it may be a bit spend, but it's well worth it.
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    You can also go with the PAC OS2 GM32 modual its a bit bulkier the GMos06 but i have heard the some get muffled audio with the gmos 06 and i know i have the pac os2 gm32 and have had no issues at all
  7. Remove Advertisements
