98 seville sts audio install...???
Results 1 to 9 of 9
Cadillac Audio, Video and Security Systems Discussion, 98 seville sts audio install...??? in Item Specific Cadillac Discussion; i am looking at either the avic-z120bt or AVH-p5200bt. I have them both coming. The gmos-06 is supposed to work ...
    goryr88 is offline Cadillac Owners Member
    Apr 2004
    43
    39
    i am looking at either the avic-z120bt or AVH-p5200bt. I have them both coming. The gmos-06 is supposed to work for this. what other plugs do i need in the back of the radio besides antenna adapter? I am also reading that the front speakers will not work as this is the BOSE setup. no onstar. will it work or not? so basically, i want to keep the stock setup and just change the head unit. what is the best mounting kit for these? one is din the other is double din. what is the best approach without changing the whole system?
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: 98 seville sts audio install...???
    Your car is a 98 your onstar will never work
    The kit you buy matters for what radio you buy.
    You could go OEM nav would be the simplest install although not plug and play and it can usually be done for under a grand. Aftermaket requries the kit, harness, antenna adapter, radio and dealing with the problems that may crop up as the computer runs through these cars radios.
    Apr 2004
    43
    39
    is it like a crapshoot with the gmos-06? i dont have onstar. what do u know about the speaker issue?
    Oct 2005
    15,987
    GMOS-06 will use your stock amp and speakers and interface your new hu with them. If your close I can help you with the install depending on where your located. The 06 is a crapshoot as you asked, some people have no problems some have tons, doesnt seem to have a rhyme or reason to it.
    Apr 2004
    43
    39
    thanks for the offer. I'm in iowa. was reading that the front bose speakers tend to burn up head units. i have also read thats not the case so i dont know what to believe. I also have an 03 cts with onstar. havent decided which would be the easier install. probly the sts.
    Oct 2005
    15,987
    Yes since the CTS uses the DIC through the radio, youd have to hack up the old radio and relocate the board a bit to make that radio fit a double din radio.
    Why looking to upgrade? just for nav?
    Apr 2004
    43
    39
    gotta a hella deal on both units from amazon. think i'll probly put the avic-z120bt in the sts. that thing is the most reliable car ive ever owned. whats the best place to buy the gmos-06? amazon has it for $85.
    Oct 2005
    15,987
    Probably amazon.
    Apr 2004
    43
    39
    will the pac os2-gm32 work in this year car?
  12. Remove Advertisements
