2002 DTS Bose/Nav "can not load software"
Results 1 to 5 of 5
Cadillac Audio, Video and Security Systems Discussion, 2002 DTS Bose/Nav "can not load software" in Item Specific Cadillac Discussion; I have an 02 DTS and the screen on my nave is stuck open and displays "Caution cannot load system ...
    srt4u2nv is offline Cadillac Owners Member
    Automobile(s): 02 DTS
    Jun 2010
    3
    I have an 02 DTS and the screen on my nave is stuck open and displays "Caution cannot load system software disk incorrect......"
    Can anyone tell me where to locate the lithium battery in the Bose Nav unit in a 2002 DTS unit model #25734875
    Thanks!!!
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: 2002 DTS Bose/Nav "can not load software"
    The lithium battery is located on the left side of the DVD unit (about 1/3 height) where there is that seam in the case. Well you actually need to open it up to get to the battery and you need a soldering gun to have it removed/replaced. The thing is, what you hope to achieve with that? Yes your lithium battery is dead and the firmware was lost so you need to replace the battery to keep the firmware in memory, but FIRST and fore most is to get the firmware burned on a CD (CD not DVD) so it can be loaded into the unit.
    With no firmware the unit ONLY accept/ejects disks in the first 5-10 seconds after it is powered on so don’t get frustrated with it, now you know how it works.
    Unless you load the firmware the screen will not retract. To load the firmware is a 3 minutes deal.
    The message you see on the screen is because the disk inside the unit is not the install disk (probably you are trying the navigation disk-no that’s not it, you need the firmware disk).
    Jun 2010
    3
    Thank so much for the help/info! do you know where can I get the firmware? opening the Nav and soldering the battery is no biggy.....
    dfever is offline Cadillac Owners Member
    5
    N*Caddy, I have the same problem but don't have access to the firmware software. From what I've read it's loaded somewhere but I don't know where, any help would be appeciated.
    Thanks,
    Dfever
    email: dfever@earthling.net
    boricuacaddy's Avatar
    boricuacaddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 Cadillac Premium AWD CTS
    Apr 2005
    Chicago, IL
    692
    Has anyone here got a hold of the Firmware software? I tried the dealer and it is a no go for me!
    David
  8. Remove Advertisements
