| Re: 2003 Seville Radio does not work Here is an update for anyone else how has run into this issue.
The Amp fuse is a 25 amp fuse located in the fuse box under the back seat behind the driver. Cleanly identified in the Owner’s Manual. Back seat comes out very easily. Just pull up from the bottom and it comes out. Watch out for the heated seat connector on the passenger side. I just laid the seat down in the foot well. I pulled the Amp fuse and found it was not blown. I put it back in and turned on the radio and it worked fine. It has been working fine for 3 weeks. Have no idea what happened but before you run out and buy a new amp or radio, pull the fuse and reinstall and see if that works. |
