04 Deville want to use OEM XM antenna for aftermarket Sirius
Results 1 to 6 of 6
Cadillac Audio, Video and Security Systems Discussion, 04 Deville want to use OEM XM antenna for aftermarket Sirius in Item Specific Cadillac Discussion; Where is the Xm tuner located? Do I need the -XM to SIRIUS Dual Input Antenna Adapter or -XM to ...
    MrCloudz is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2008
    9
    or
    -XM to SIRIUS Single Input Antenna Adapter
    Thanks!
    Cliff8928 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V
    Jul 2008
    Long Grove, IL
    36
    416
    Re: 04 Deville want to use OEM XM antenna for aftermarket Sirius
    what antenna do you have?
    The XM Receiver is on the drivers side in the trunk behind the trim panel attached to the reinforcement panel. You can see the two bolts holding it in going through the reinforcement panel.
    Sep 2008
    9
    OEM sharkfin xm antenna. I'm going to go take a look now. I plan to remove the xm tuner and replace it with a pioneer sirius tuner, retaining the oem antenna. Main reason for this is that I hate the sirius micro dot antennas. I went through 4 of them in my grand cherokee (no pinching).
    Jul 2008
    Long Grove, IL
    36
    416
    Shark fin? It's kinda vague seeing as GM has used no fewer than 5 different antennas over the years.. Some have 2 leads, some have one. Depends on which one it is.
    Sep 2008
    9
    btw I looked and it's a dual antenna tuner, so I ordered "XM to SIRIUS Dual Input Antenna Adapter" I will let you guys know how it works out.
    besjr69 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac DeVille DTS
    Feb 2011
    3
    McCloudz,
    Just wondering if this ever worked. I have an '05 with an aftermarket radio, amplifier bypass. I would like to add Satellite Radio, but want to use the OEM antenna instead of the magnet mount.
    Bobby
  9. Remove Advertisements
