Double Din For a '96 Deville?
Results 1 to 3 of 3
Cadillac Audio, Video and Security Systems Discussion, Double Din For a '96 Deville? in Item Specific Cadillac Discussion; So I bought a double din unit, and installed it in my '96 Deville this past weekend. Sweet! The only ...
    popejohnny is offline Cadillac Owners Member
    Automobile(s): '96 Deville
    Oct 2005
    Central Jerz
    41
    18
    The only problem I have, and why I turn to you, loyal readers, is this:
    Previously I had a standard single-din aftermarket stereo, installed with the Metra kit (or was it Schoche, whatever), that has the pocket on the bottom.
    Being that nobody makes a double din kit for DeVilles, I hacked the Metra kit apart so it would fit the new stereo. Great! So it's installed, and it works, but there's a gap on either side of the stereo now, and only on the upper half. It's an eyesore, if you ask me.
    I'm well aware nobody makes a kit, but does anyone know if there are any shops that have fabricated a kit for their Deville? Price? Or does anyone know if there is actually a double din kit from another vehicle that could work, with slight modification?
    I could buy the ABS myself and sit and sand it until it looks perfect, but I'm lazy.
    Any suggestions?
    Big L is offline Cadillac Owners Member
    Automobile(s): 2013 XTS Luxury, 2001 DHS, 1976 Seville
    May 2008
    California
    81
    Re: Double Din For a '96 Deville?
    I have an 01 DHS and encountered the same problem. I bought a 1/16" sheet of abs from ebay and razor cut the center to fit my screen. Then I just used adhesive to attach it to the install kit. After the trim is re applied, you cant tell. Also, crutchfield sells a universal double din kit.
    Now if only I could get the harness to work and stop blowing fuses!
    Necrosan is offline Cadillac Owners Enthusiast
    Automobile(s): 1994 Cadillac Eldorado Touring Coupe
    Jan 2008
    MKE
    821
    Don't use a harness.
