headunit, antenna, or brain?
Results 1 to 7 of 7
Cadillac Audio, Video and Security Systems Discussion, headunit, antenna, or brain? in Item Specific Cadillac Discussion; radio comes on and stays on, sound only for a sec then off then on then off in two second ...
    kman3786 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    10
    radio comes on and stays on, sound only for a sec then off then on then off in two second cycles, while the antenna cycles up and down for two seconds at a time. Someone replaced with another power antenna to fix, and didnt work.
    ideas???
    i think the tape will work but havent tried it.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: headunit, antenna, or brain?
    year
    make
    model
    radio option
    Jun 2008
    10
    radio turns on, sound for only a second, while antenna goes up and down, sound goes on and off . someone replaced antenna did not fix problem. clicking in trunk as antenna goes up and down and sound cycles on and off. whats the problem the headunit brain or what. plan to put cd tape combo in to replace tape. I have a hunch the tape player will work just fine and play but havent tried. something related to antenna control and signal.
    Jun 2008
    10
    1994 sts tape radio unit. replacing with cd tape radio headunit. could that fix the problem?
    still_walkin's Avatar
    still_walkin is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Cadillac deville sedan 1986 cadillac deville RIP
    Apr 2007
    san diego
    33
    1,498
    Sounds like your using a newer factory radio in an older car is there a amp fuse on the memory wire. The clicking in the trunk could be your rear speakers terminals touching is that wiring stock or you changed it
    Jun 2008
    10
    Forget it if you read, i clearly stated everything is stock and has not been altered.
    For some reason I thought this forum would be more helpful as the Volvo one was with my last car.
    Lee
    Chicano-Mexicano's Avatar
    Chicano-Mexicano is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldorado Sports Coupe
    Nov 2007
    Chicago
    28
    271
    Quote Originally Posted by kman3786 View Post
    Lee
    Your not giving us much to go on, theirs two radios for the 94 Seville theirs the base radio (AM/FM/Cassette) and the Bose (AM/FM/CD/Cassette) which while and excellent system it can be a real bitch becasue the head unit is just a controller and the Amp is where the action is (which could be your problem and an expensive one at that) or you could be having a problem with on of the 4 independent door speaker amps (again can be expensive) but just saying that it's a 94 STS with a tape radio doesn't give us much to go on.
  10. Remove Advertisements
