  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > General Discussion > General Cadillac Discussion > Cadillac Audio, Video and Security Systems
Cadillac Audio, Video and Security Systems Section for discussions in relation to stereo, navigation, DVDs, alarms, etcetera.
Cadillac Forums: to all you audio guys out there
Old 05-28-08, 09:45 PM
kdsevillle's Avatar
Cadillac(s): Seville SLS (STSi), 04 Z06 LeMans edition
View kdsevillle's Photo Album
Casino Cash: $6242
Exclamation to all you audio guys out there
Something is wrong with my system. All the sudden when I turn the car off, My amp stays on. It's never done this before until last week (batt died). What could have caused this????
Set up - Stock BOSE head unit, two 12in P2 fosgate's with a 1000watt Sony AMP. REM wire is hooked up to a fuse. If the fuse is blown, could that keep the amp running???
Thanks all!!!!
  #2 (permalink)
Old 05-29-08, 01:15 AM
Cadillac Owners Enthusiast
Cadillac(s): 1994 Cadillac Eldorado Touring Coupe
View Necrosan's Photo Album
Casino Cash: $11920
Re: to all you audio guys out there
Check to make sure the fuse you're using isn't an always +12V. I'd probably run a wire from the stock headunit that's tapped in to the ignition only 12v. Otherwise you're gonna have to find a for sure on ignition only wire or risk a dying battery all the time...
  #3 (permalink)
Old 05-29-08, 04:33 PM
Chicano-Mexicano's Avatar
Cadillac(s): 1993 Eldorado Sports Coupe
View Chicano-Mexicano's Photo Album
Casino Cash: $4295
Thats not necessarily a good Idea becasue it can reek hell on your cars anti-theft system or so I've heard. What box do you have your amp hooked to the under hood bock or dash box?
  #4 (permalink)
Old 05-29-08, 05:28 PM
kdsevillle's Avatar
Casino Cash: $6242
its the fuse box under the rear seat. It's a 2000 SLS
  #5 (permalink)
Old 05-29-08, 08:01 PM
Casino Cash: $4295
Ok. Get a volt meter and check the if the fuse were your amp is plug into is a constant 12v or ignition only.
  #6 (permalink)
Old 06-04-08, 02:48 PM
JmOz's Avatar
Cadillac(s): 1998 Cadillac STS 76k
View JmOz's Photo Album
Casino Cash: $1415
my amp stayed on to before. but then i put in a switch to turn the amp on and off you should get that
  #7 (permalink)
Old 06-06-08, 08:20 AM
Cadillac(s): 1986 Cadillac deville sedan
View still_walkin's Photo Album
Casino Cash: $6869
The easiest way to fix this your amps have a remote out and they should be wired to the aftermarket radios antenna. If you have it wired to the constant(memory wire )that's why it stays on or the memory wire and the antenna wire are touching check your wiring
  #8 (permalink)
Old 06-14-08, 11:27 PM
bigjoker's Avatar
Cadillac(s): Cadillac 2003 deville
View bigjoker's Photo Album
Casino Cash: $275
your remote wire don't need a fuse. your power wire does.
  #9 (permalink)
Old 06-14-08, 11:39 PM
Casino Cash: $6869
What Necrosan was trying to say is that if you are using a factory radio if you tapped into the wirrng you have your remote wire pliced with you 12v constant aka memory wire which the 12v constant wire gives your radio just enough juice to keep the time and settings saved so you need to move your remote wire to the antenna wire or the 12v so you have a constant battery drain that's why your amp is always on
audio, guys
attach your bluetooth cell phone to onstar
flash wax for your cadillac
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum
