| Cadillac Audio, Video and Security Systems Section for discussions in relation to stereo, navigation, DVDs, alarms, etcetera. | Cadillac Forums: 2001 DHS Factory Navigation Replacement
05-19-08, 11:02 PM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | 2001 DHS Factory Navigation Replacement Hi. I'm posting in hopes someone has successfully replaced their stock navigation and can help me out. I have a 2001 Deville DHS and the only harness I've found that fits is the PAC OS2-GM32. Now, this says easy plug n play...nope. I've blown my screen fuse everytime I plug in the wire harness only (not the interface box, just the cable). I've also tried the GMOS-06, by Metra Electronics, but this does not fit. I am desperatly wanting to install my new double din screen I received for Christmas, so if anyone has any relevant info, I'd really really appreciate it!! Thanks. |
05-19-08, 11:28 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: 2001 DHS Factory Navigation Replacement yup
your car has a different due to your nav and since its a rare system all the companies didnt account for this
you have to repin your nav system plug along with some other work
where are you located, if you closed to Pgh PA i can help you with it |
05-20-08, 12:53 AM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: 2001 DHS Factory Navigation Replacement unfortunately, I'm located in California. Is this something one can easily do? |
05-20-08, 01:31 AM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: 2001 DHS Factory Navigation Replacement egh....
likely not...
i could maybe devise a harness which would adapt your wires into the correct positions and then youll have the right plug to use the gmos-06 |
05-20-08, 02:39 AM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: 2001 DHS Factory Navigation Replacement the gmos does not fit with my car's harness. Could this be done with the pac-audio? |
05-20-08, 03:26 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: 2001 DHS Factory Navigation Replacement i know it doesnt
i said id MAKE a harness to adapt YOUR harness into the 32 pin that the GMOS-06 needs.... |
05-20-08, 04:26 PM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: 2001 DHS Factory Navigation Replacement I'm sorry, I thought you were referring to changing the wire configuration of an exisiting harness, not making a new harness connection piece. What would you charge for this? |
05-20-08, 04:40 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: 2001 DHS Factory Navigation Replacement idk
i have to look at the schmatics to see if you even have all the wires you need on your harness... |
05-20-08, 07:00 PM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: 2001 DHS Factory Navigation Replacement I have a jpeg of my stereo schemactic if you want it |
05-20-08, 07:34 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: 2001 DHS Factory Navigation Replacement no need
i have access to GM ESI (electronic service information)
basically the full dealers how to on anything gm 1998-2005 |
05-20-08, 07:41 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: 2001 DHS Factory Navigation Replacement actually
i just looked it over
the pin outs are about the same and the only differences shouldnt cause any issues
if i were you id sand down your stock plugs guides so that the plug will plug into a gmos-06 and just save yourself the money |
05-20-08, 10:02 PM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: 2001 DHS Factory Navigation Replacement unfortunately, I've already returned the gmos. I am currently still in possession of the pac audio OS2-GM32. |
05-23-08, 10:44 PM
| | Cadillac Owners Member Cadillac(s): 2001 Cadillac DHS | | Join Date: May 2008 Location: California | | | Re: 2001 DHS Factory Navigation Replacement has anyone successfully swapped their navigation for an aftermarket deck? |
05-23-08, 10:45 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: 2001 DHS Factory Navigation Replacement probably not
like i said its a rare outdated option and those who have it usually dont care to replace it | | Tags: aftermarket, audio, factory, harness, install, nav, navigation, oem, replace, swap, switch | | Cadillac Discussion Tools | | |
Censor is ON | | | |
