| Cadillac Audio, Video and Security Systems Section for discussions in relation to stereo, navigation, DVDs, alarms, etcetera. | Cadillac Forums: 02 escalade w/eclipse avn2454,speed sensor ,question!
05-15-08, 08:08 PM
|  | Cadillac Owners Member Cadillac(s): Cadillac escalade 2002 | | | | | 02 escalade w/eclipse avn2454,speed sensor ,question! i have a eclipse avn 2454 and i have the speed sensor wire ,,but where exactly this should go to what wire ?,,
the plug that come from the back has 3 wires:
-green
-purple/with white line- speed sensor wire
-red/ with wihte line
my dvd is playing but only in a backround,,if i want to acces ""dvd map error" i get,,
im working in a 2002 escalade
any help will be apreciate,, |
05-15-08, 11:19 PM
|  | Cadillac Owners Member Cadillac(s): Cadillac escalade 2002 | | | | | Re: 02 escalade w/eclipse avn2454,speed sensor ,question! fixed the video,,
red wire to ground!,work,all ther way
but where do i connect the speed sensor wire?
and maybe someone has the 2002 escalade cadilac wiring diagram,,
thanks |
07-11-08, 10:35 PM
| | Cadillac Owners Member Cadillac(s): 2002 Cadillac Escalade | | Join Date: Nov 2007 Location: Tempe, AZ | | Re: 02 escalade w/eclipse avn2454,speed sensor ,question! have a question for you, I have an 02 Escalade as well but how did you fit the double din radio into the 1.3 din spot, did you buy a new bezel (if so where did you purchase it) or did you shave out the surrounding area?
this question is for everyone to answer if you have done this, any info would be greatly appreciated. |
12-18-08, 05:30 PM
|  | Cadillac Owners Member Cadillac(s): 2003 escalade | | | | | Re: 02 escalade w/eclipse avn2454,speed sensor ,question! u have to hook it to the sensor wire from ur transmission thats what my friend did to my escalade |
12-19-08, 02:20 AM
| | Cadillac Owners Fanatic Cadillac(s): STS-V - XLR | | Join Date: Jul 2008 Location: Long Grove, IL Age: 29 | | | Re: 02 escalade w/eclipse avn2454,speed sensor ,question! Nah, in a 02 escalade the wire is already there. The old Delco radios had VSS inputs for the SCV.
The VSS wire is in the factory harness. Connector C2 pin 16. It's the dark green / White wire. |
12-20-08, 11:22 AM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: 02 escalade w/eclipse avn2454,speed sensor ,question! cliff has it correct
answer to ladeout
you must buy and upgrade to an 03+ dash bezel
from there its a simple install so long as you buy the correct harness for your application |
03-27-09, 12:14 AM
| | Cadillac Owners Enthusiast Cadillac(s): 02 Diamond White Pearl Escalade | | Join Date: Feb 2009 Location: IL, USA | | | Re: 02 escalade w/eclipse avn2454,speed sensor ,question! Quote:
Originally Posted by Cliff8928 Nah, in a 02 escalade the wire is already there. The old Delco radios had VSS inputs for the SCV.
The VSS wire is in the factory harness. Connector C2 pin 16. It's the dark green / White wire. | Ok I am not sure which harness you are talking about - the Radio Harness? There are two so which is C2? | | Cadillac Discussion Tools | | |
Censor is ON | | | |
