The Right Way to Wire in an amp for aftermarket subs - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Cadillac Audio, Video and Security Systems Discussion, The Right Way to Wire in an amp for aftermarket subs in Item Specific Cadillac Discussion; what is an LOC? Do u need it? Ok, so let me get this straight: -Leave the rear factory subs ...
  1. #16
    TheKid is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2008
    35
    180
    Re: The Right Way to Wire in an amp for aftermarket subs
    -Leave the rear factory subs intact.
    -Splice into the rear factory sub wires and the other ends go to the RCA "IN" ports on the aftermarket amp
    My question is, do you lose any volume, sound quality of the factory system? And does this change the ohms on the factory subs by tapping off in parallel like this?
  2. #17
    m1str816 is offline Cadillac Owners Member
    Automobile(s): 2000 Deville (Base)
    Aug 2011
    37
    3
    I have a 2000 deville, and I'm sure this would work for it, as i'm only looking to power a 10" kicker sub with an xplode 222 amp. Can you possibly explain in more detail, such as the fuse box and exactly where to put the wire for the remote in the fuse? I would really appreciate this.
  3. #18
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    Stay away from Sony Xplode, get a Kenwood KAC5204 amp, it powered my 10" Kicker comp perfectly.
  5. #19
    Aug 2011
    37
    3
    Vic, do you know what dan is talking about when he says the 'hot side' of the ignition fuse? I know where the fuse box is located (under the rear seat driver side) but I don't quite understand what he means by "hot side" of the fuse?
  6. #20
    Aug 2011
    37
    3
    i'm sorry, i meant vince....typing from my phone.
  7. Remove Advertisements
