2000 Deville radio shuts off after 3 seconds
Results 1 to 7 of 7
Cadillac Audio, Video and Security Systems Discussion, 2000 Deville radio shuts off after 3 seconds in Item Specific Cadillac Discussion; Hello, My subwoofer went bad (rattling) and I continued to play the radio. One day, the radio (OEM) suddenly stopped. ...
    crusienfloat is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    4
    Question2000 Deville radio shuts off after 3 seconds
    Hello,
    My subwoofer went bad (rattling) and I continued to play the radio. One day, the radio (OEM) suddenly stopped. The clock continued to display the proper time. When I started the car, the radio displayed a station id for 3 seconds then shut off. There was no sound of any kind. I lost my door and key in the ignition warning chimes.
    I purchased an OEM radio on Ebay and had the dealer to perform a VIN relearn on the radio. This radio has a CD player. My original radio did not hav a CD player. Now, the replacement radio is shutting down after 3 seconds just as the original radio. Is this an amp problem?
    Thanks
    Mar 2008
    4
    Re: 2000 Deville radio shuts off after 3 seconds
    Anyone?
    Why would two radios respond exactly the same? Did the blown subwoofer cause damage to the system?
    Mar 2008
    4
    lol, both radios are good. I was about to disconnect the battery cables, but noticed a fuse relay box. I pulled and replaced the fuses for the audio (15) and the amp (30) and the lovely sound of music filled the car. Evidently, having the blown subwoofer connected cause the amp to shut down. The problem is solved. Thanks for all of the post regarding similar issues.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    If the amplifier will not communicate with the radio that is what will happen.
    First thing to check is for power.
    Next is to replace the amp. Sometimes cycling power to the amp will restore operation.
    If it happens again, you likely need a new amplifier.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    forgot logic reset lol
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Usually if you have logic lock like that, cycling the power is only a temporary fix.
    I have restored operation to a few of them that way but I always tell the customer that next time it will probably need an amplifier.
    Mar 2008
    4
    I am bold, I reconnected the blown subwoofer and the radio shutdown. I disconnected the woofer, pulled the fuses again, and the radio responded with music. I will replace the subwoofer.
  10. Remove Advertisements
